#1 2023-03-17 23:09:27
oui
no automatic internet connection (wired) after chimaera update any mor
no automatic internet connection (wired) after chimaera update (today) any more
how to try to recover it pls.
I did start from USB stick where chimaera without other files is present
update
upgrade
snapshotped
(snapshot did refuse to build ISO)
I did copy /home/work/ content into a free partition
update grub
an restart
Chimaera did start willing and all seem to work ...
... excepted the automatic connection with the wired internet modem.
Principal question:
What can I try to do?
Accessory question:
Can I, as soon I get internet again, update that new actual installation chimaera and upgrade it to the actual daedalus? Is perhaps a special way known or what can I try to do?
#2 2023-03-17 23:38:49
Re: no automatic internet connection (wired) after chimaera update any mor
I'm guessing that you didn't have the wicd metapackage installed. If you did have it, you would have automatically gotten network-manager to replace it. You can bring up the wired connection and install n-m with the following commands (as root).
dhclient eth0
apt update
apt install network-manager-gnome
Or, if you don't want a gui program for connecting to the network, you could just edit /etc/network/interfaces and add the following:
auto eth0
iface eth0 inet dhcp
You can do one or the other, but don't do both of those things.
