#1 2022-09-09 21:09:15
recklessswing
[SOLVED] Installing openmediavault on top of devuan
Is it possible? It's quite possible to install omv on top of freshly installed debian. Can I do it with devuan?
#2 2022-09-10 09:06:17
Re: [SOLVED] Installing openmediavault on top of devuan
Haven't tried it but their colllectd .deb has a sysvinit script as well as a systemd unit file so it looks promising.
Why don't you experiment in a disposable VM and report back?
#3 2022-09-19 22:31:58
recklessswing
Didn't work. It gave this output:
openmediavault : Depends: netplan.io but it is not installable
                  Depends: systemd but it is not installable
                  Depends: systemd-sysv but it is not installable
bash: omv-confdbadm: command not found
root@somepc:/home/user# rm /etc/apt/sources.list.d/openmediavault.list
#4 2022-10-02 16:26:47
b1t5murf
I've looked at porting OMV to Devuan a couple times, but the author of OMV has tied the majority of his code directly to systemd behavior.
It will require a fork and a lot of unwinding of hardcoded systemd stuff to get it going.
#5 2022-12-11 19:06:07
recklessswing
I think it won't work then. Thanks for info.
