#1 2017-01-20 16:24:02
Alice
d1g
Cannot install KDE 5 (kde-plasma-desktop) on Ascii
I tried this:
sed -i "s/jessie/ascii/" /etc/apt/sources.list
apt-get update
apt-get upgrade
apt-get install kde-plasma-desktop
Building dependency tree
kde-plasma-desktop : Depends: kde-baseapps (>= 4:4.11.3) but it is not going to be installed
                      Depends: kde-runtime (>= 4:4.11.3) but it is not going to be installed
                      Depends: plasma-workspace (>= 4:5.0.0) but it is not going to be installed
                      Depends: plasma-desktop (>= 4:5.0.0) but it is not going to be installed
                      Recommends: sddm (>= 0.11) but it is not going to be installed
And if I try to install mentioned dependencies one by one, eventually I get into dead end. Last time it was:
upower : Depends: libimobiledevice4 (>= 0.9.7) but it is not installable
~Package ~"Suite: ASCII"
________________________________________
Project: devuan/devuan-project
Issue: #56
By: Alice
#2 2017-05-08 07:00:51
ghp
Re: Cannot install KDE 5 (kde-plasma-desktop) on Ascii
Hallo Alice,
I've only got some 20 years experience with Linux, and it takes me a day to upgrade a system with KDE from Jessie to Ascii, due to dependency problems, kdm being replaced by sddm and whatnot.  Reinstalling may be a lot easier, if you can save what you need from your current system.
Good luck,
Gerard
#3 2017-08-04 11:41:35
penguinwrangler
I've the same problem.  I completely failed trying to cleanly install Ascii so installed Jessie and then upgraded following https://talk.devuan.org/t/upgrading-dev … -ascii/363.
All went smoothly except that only Xfce was available, not KDE, when I logged in via Slim.
When I tried to install KDE, I was told:
root@aardvark:~# apt-get install task-kde-desktop
task-kde-desktop : Depends: tasksel (= 3.33+devuan0.3) but 3.33+devuan1.0 is to be installed
                    Depends: kdm but it is not installable
                    Recommends: kdeaccessibility but it is not going to be installed
                    Recommends: k3b but it is not going to be installed
                    Recommends: k3b-i18n but it is not going to be installed
                    Recommends: plasma-widget-networkmanagement but it is not installable
                    Recommends: kdesudo but it is not going to be installed
                    Recommends: libreoffice-kde but it is not going to be installed
                    Recommends: apper but it is not going to be installed
                    Recommends: libreoffice but it is not going to be installed
                    Recommends: libreoffice-help-en-us but it is not going to be installed
                    Recommends: mythes-en-us but it is not going to be installed
root@aardvark:~#
When I then tried to explicitly install KDM, I was told that it wasn't available but was replaced by kde-wallpapers.  That installed cleanly but I still get the same error trying to install task-kde-desktop.
Does anyone know how to work around this?
#4 2017-08-04 12:49:12
penguinwrangler
In case it helps anyone following this thread, I now have KDE 5 running (very) nicely.
The magic steps to fix the above were:
wget https://packages.devuan.org/devuan/pool/main/t/tasksel/task-kde-desktop_3.33%2Bdevuan1.0_all.deb
dpkg -i --ignore-depends=kdm task-kde-desktop_3.33+devuan1.0_all.deb
apt-get install kde-standard
apt --fix-broken install
In all honesty, I'm not sure that the wget + dpkg for task-kde-desktop were strictly necessary.  It complained when trying to install kde-standard and suggested --fix-broken.  When I did that, it all untangled itself and installed smoothly.  Unfortunately, I'm not really in a position to uninstall it and see exactly which steps were critical.  If anyone following this can try just "apt-get install kde-standard" and see if that works rather than the "apt-get install task-kde-desktop", that may be all you need to do...
#5 2017-08-18 07:04:08
nathg
Found this old thread & issue. Still ascii has problem with package " tasksel ", need updation of repo.
Still one may for DE's ,
aptitude install kde-plasma-desktop
aptitude install kde-standard
aptitude install mate-desktop
cheers,
Edit: correction of code.
