#1 2022-01-14 07:36:59
EDX-0
zram service
maybe self plug but, for anyone that wants to use zram in their install i prepared a repo with a service script that does the job, all it needs is zramctl which is part of the util-linux package.
github: https://github.com/eylles/zram-service
gitlab: https://gitlab.com/eylles/zram-service
codeberg: https://codeberg.org/eylles/zram-service
not sure if submitting that to debian or straight up go and try to get it into devuan?
edit: anyone who wants to help adding proper support for openrc and runit?
#2 2022-01-14 07:46:55
hevidevi
Re: zram service
id say submit it to devuan first as a .deb
debian already has zram-tools with the required systemd service files.
https://packages.debian.org/bullseye/al … s/filelist
there is also this on the wiki in below link buts its self setup.
https://wiki.debian.org/ZRam
#3 2022-01-14 07:55:01
EDX-0
Re: zram service
yeh, i know about the wiki entry, in my opinion using perl in an initscript for something that can be done with a simple awk command is rather dumb
for the script in the repo i added a couple extra facilites like restarting and status along loading a config file, u know to facilitate things a little for the folks that do intend to use this.
#4 2022-01-14 08:00:21
hevidevi
Re: zram service
yeah that is why yours is probably a little more user friendly. Anyway, thanks ill give your script a try.
#5 2022-01-14 08:06:14
EDX-0
Re: zram service
welp, i'm an airhead so the moment i learn to do something i gotta script it, that way i don't need to remember how it is done lol
#6 2022-01-14 18:44:39
Re: zram service
Looks like the Debian zram-tools maintainer doesn't care about non-systemd support:
https://bugs.debian.org/cgi-bin/bugrepo … bug=960524
Devuan's runit will use sysvinit scripts. Search the boards if you want a method for setting up proper supervision with runit, it has been covered here before.
For OpenRC see https://github.com/vaeth/zram-init/blob … /zram-init
#7 2022-01-15 07:33:56
hevidevi
Re: zram service
i found this also if you are interested in looking through it EDX-0, It has some service files for openrc and runit mentioned on the readme.
Not sure if it would port over to devuan as i installed this one on my artixlinux machine that uses openrc init.
https://github.com/atweiden/zramen
