#1 2021-05-17 11:01:38
dajun
how to change desktop, grub, lightdm background ?
I installed openbox + lightdm on devuan 4,
the desktop is using "cinnabar" images,
how to change desktop, grub, lightdm background to the "darkpurpy", they are not listed.
# update-alternatives --config desktop-background
There are 6 choices for the alternative desktop-background (providing /usr/share/images/desktop-base/desktop-background).
  Selection    Path                                                               Priority   Status
* 0            /usr/share/images/desktop-base/your-way_cinnabar-wide-large.svg     60        auto mode
  1            /usr/share/images/desktop-base/your-way_cinnabar-narrow-large.png   40        manual mode
  2            /usr/share/images/desktop-base/your-way_cinnabar-narrow-large.svg   45        manual mode
  3            /usr/share/images/desktop-base/your-way_cinnabar-narrow-small.png   25        manual mode
  4            /usr/share/images/desktop-base/your-way_cinnabar-wide-large.png     55        manual mode
  5            /usr/share/images/desktop-base/your-way_cinnabar-wide-large.svg     60        manual mode
  6            /usr/share/images/desktop-base/your-way_cinnabar-wide-small.png     40        manual mode
Press <enter> to keep the current choice[*], or type selection number:
# ls /usr/share/images/desktop-base/
beo-greeter-narrow-large.png    lines-lockscreen.xml                 your-way_darkpurpy-wide-large.png
beo-greeter-wide-large.png      lines.xml                            your-way_darkpurpy-wide-large.svg
darkpurpy.xml                   your-way_cinnabar-narrow-large.png   your-way_purpy-narrow-large.png
desktop-background              your-way_cinnabar-narrow-large.svg   your-way_purpy-narrow-large.svg
desktop-background.xml          your-way_cinnabar-narrow-small.png   your-way_purpy-narrow-small.png
desktop-lightdm-background      your-way_cinnabar-wide-large.png     your-way_purpy-wide-large.png
desktop-lightdm-background.xml  your-way_cinnabar-wide-large.svg     your-way_purpy-wide-large.svg
desktop-splash                  your-way_cinnabar-wide-small.png     your-way_purpy-wide-small.png
greeter-wide-large.png          your-way_darkpurpy-narrow-large.svg
#2 2021-05-17 14:34:55
dice
Re: how to change desktop, grub, lightdm background ?
you would probably have to install them using update-alternatives if they are available and give a higher priority than the cinnabar theme.
https://manpages.debian.org/jessie/dpkg … .8.en.html
