#1 2021-01-16 21:53:02
bimon
Tried to add a printer manually and it did not work for me.
I have another Debian Wheezy host with an old HP LJ 1000W printer connected to it.
I tried a CUPS wizard to add this printer as an IPP printer, but it did not work.
Then I have discovered following command:
lpadmin -p LaserJet -E -v ipp://x.x.x.x:631/printers/HP_LaserJet -m everywhere
and it created the printer which works from GUI programs like text editors.
After sending a document a Trinity popup appears which still indicates an error, but then the document is printed on the network printer anyway.
Please note: my workstation is running Devuan ASCII dist-upgraded to the backports.
Following commands used to install drivers on both CUPS server and client:
apt-get install printer-driver-foo2zjs hpijs-ppds hannah-foo2zjs
apt-get purge hplip hplip-cups  hplip-data  hplip-doc
CUPS on the server always worked for sure even since I had another Debian on my workstation a few years ago.
And also opening its IP in the browser and directing to print a test page from CUPS web interface works fine.
#2 2021-01-16 22:01:09
Re: Tried to add a printer manually and it did not work for me.
There is no such thing as "dist-upgrade to the backports".  Perhaps that is the root cause of your many malfunctions.  You may never unravel that hairball that you have created.
#3 2021-01-16 22:04:05
bimon
apt-get dist-upgrade -t=ascii-backports
Actually I always treated my HP 1000W printer config as a magic for myself. It was relatively difficult to do even in Debian without backports.
I am almost sure nothing changes if I downgrade from backports back to the updates and security.
