#1 2020-01-29 16:29:39
randomer
[XFCE] Question regarding tray icons and the notification area
Tray icons such as the xfce4-battery-plugin or pavucontrol don't appear in the notification area but sit next to it on the panel. I'd prefer having all of them sitting in the dedicated notification area. How can i make them appear in the notification area? Simply moving them doesn't work obviously.
#2 2020-01-29 21:20:16
bgstack15
Re: [XFCE] Question regarding tray icons and the notification area
The xfce plugins are separate "applets" in xfce; they integrate in special ways to the xfce4-panel, perhaps even only by providing an additional library the panel executable loads. They are not generating the same consumable icons that can be captured in the regular "system tray" that is the Notification Area.
#3 2020-01-29 21:30:28
randomer
This shouldn't be the case for pavucontrol, right? Why doesn't the icon integrate with the notification area? There has to be a way to make it integrate.
#4 2020-01-30 01:20:46
bgstack15
Sorry, that's an xfce4 plugin!
 apt-cache search xfce4-pulseaudio-plugin
xfce4-pulseaudio-plugin - Xfce4 panel plugin to control pulseaudio
If you want a system tray icon for audio control, I recommend volumeicon, but I think it might be alsa-only.
#5 2020-01-30 03:05:24
zephyr
bgstack15 wrote:  If you want a system tray icon for audio control, I recommend volumeicon, but I think it might be alsa-only.
Try pnmixer, use it for alsa but will work with pulseaudio!
cheers
zephyr
#6 2020-01-30 03:50:39
randomer
You are right, my bad. I don't get it why the XFCE devs thought it'd be a good idea having those seperated.
I am currently using volumeicon with alsa but going to use to pulseaudio for convenient switching between sound cards.
cheers
zephyr
I will check this one out. Thanks!
#7 2020-01-30 14:49:01
+1
And yes, it works fine with PA, despite the name that suggests otherwise.
"Il semble que la perfection soit atteinte non quand il n'y a plus rien à ajouter, mais quand il n'y a plus rien à retrancher." — Antoine de Saint-Exupéry
#8 2020-01-30 18:25:48
MiyoLinux
I like volumeicon-alsa and pnmixer...usually prefer volumeicon-alsa.
pasystray is a pulseaudio volume icon specifically made to go in the system tray. It's in the repos.
#9 2020-01-30 18:50:04
randomer
Perfect. Should've tried volumeicon-alsa before looking into other alternatives.
Thank you, i didn't know there is such thing in the repos.
