#1 2020-01-13 05:32:27
basati
where is the ceres pool ?
I need a deb file from the ceres pool.
linux-image-5.4.0-2-amd64 or higher
I can't find the wax pool.
Where is it? How do I get that file?
I happen to have bought an asus ux333fa and have a lot of driver and module problems. They say that kernel version 5.4 solves it.
Any ideas
Gora gu ta gutarrok
8=þ
#2 2020-01-13 05:35:02
basati
Re: where is the ceres pool ?
sorry ceres pool
Gora gu ta gutarrok
8=þ
#3 2020-01-13 06:22:34
basati
It's not necessary anymore, I used debian's.
Thank you
Basati
Gora gu ta gutarrok
8=þ
#4 2020-01-13 16:19:11
AFAIUI, the Devuan repositories are mirrored from Debian's (but without the init system that shall not be named) using special magic:
https://dev1galaxy.org/viewtopic.php?id=3192
So there is no ceres pool, as such.
