#1 2020-01-07 01:31:35
randomer
XFCE Power Manager doesn't show current charge in tray
The XFCE Power Manager doesn't update the current charge. It shows 100% battery and plugged in even though it is not plugged in and the charge is decreasing. When i click on tray icon and open battery/device info, the info seems correct and updated. It worked fine in ASCII. Any idea?
#2 2020-01-07 01:42:39
aut0exec
Re: XFCE Power Manager doesn't show current charge in tray
Cinnamon has the same issue. I know that doesn't help much but you can check it from the CLI with Upower periodically until things get fixed!
#3 2020-01-07 01:47:39
randomer
Ur reply is actually very helpful. Now i know the issue isn't on my end, right?
#4 2020-01-07 11:28:40
HevyDevy
I can confirm this behavior also with power manager on the laptop.
If you are using the xfce4 panel, there is a battery monitor plugin you can configure. You can have the panel icon show or a few other display options, you can also set levels and actions similar to power manager.
#5 2020-01-07 20:41:01
GNUser
I don't use a power manager on my Devuan ASCII laptop, but like having a battery icon in system tray. So I wrote a minimalistic utility that does only that:
https://github.com/bdantas/battery-monitor
#6 2020-01-08 00:20:43
randomer
I prefer the XFCE Power Manager because it integrates with the notification area and doesn't just sit on the panel.
That looks cool. Thank you for sharing.
#7 2020-01-08 00:53:25
GNUser is cool.  Provides lots of goodies like that.
#8 2020-01-08 02:39:52
bgstack15
Thank for sharing the battery icon utility, GNUser. The world needs more simple utilities like this one.
#9 2020-01-08 05:53:43
randomer
Will the XFCE Power Manager bug be fixed in the Beowulf stable release or is it also existent in Debian Buster and therefore won't be fixed?
@GNUser I tried your battery monitor but the icon was not displayed correctly. Instead there was a blank icon in the notification area. I followed the steps on the GitHub and double-checked if the icon files are present in /usr/share/icons/battery-monitor.
#10 2020-01-08 10:27:29
HevyDevy
A nice addition to your script would be to allow the users preferred icon theme battery icons to show.
#11 2020-01-08 15:00:24
GNUser
@randomer - Did you follow all the steps under "Installation"? What architecture are you using (x86, x86_64, or something else)?
Also, I failed to mention that mktrayicon depends on gtk3. Is gtk3 installed on your system? If not, do this: sudo apt install libgtk-3-0 then give it another try.
If it still doesn't work, try manually creating a systray icon with mktrayicon -i /path/to/any/icon.png. If gtk3 is installed and that doesn't work, it may be a bug in your system tray/desktop environment.
#12 2020-01-08 15:08:24
GNUser
BTW I added 2>/dev/null to line 36 to prevent the cosmetic 'divide by 0' error when on a/c power.
The github repository has been updated to reflect this.
#13 2020-01-08 15:10:29
GNUser
@HevyDevy - gtk3 and mktrayicon have built-in support for icon themes. If you'd like to use my script with your icon theme:
1. delete every instance of .png in the script
2. on line 61, change $icon_dir/$icon to just $icon
#14 2020-01-08 15:18:13
GNUser
@bgstack15 - You're welcome!
#15 2020-01-09 10:52:07
HevyDevy
Ok thanks for that.
