#1 2019-03-30 21:12:10
Spaceman Spiff
No Grub menu
I have a question. I installed Devuan and everything works, except the grub screen; which, never appears during boot up. Did I do something wrong?
#2 2019-03-31 00:10:27
Re: No Grub menu
Does the GRUB menu appear if you (repeatedly) tap the <shift> key whilst the system is booting up?
If you have installed a non-UEFI system then you can check if GRUB is the bootloader by running
# dd if=/dev/sda bs=512 count=1 | xxd
Then see if the "GRUB .Geom.Hard Disk.Read. Error" message appears in the right hand side output.
For a UEFI system, use
# efibootmgr
And check the names of the boot entries.
Or use the boot-info-script package (/usr/sbin/bootinfoscript) to investigate further.
If you're using GRUB then edit the GRUB_TIMEOUT setting in /etc/default/grub then run update-grub (as root) to change the timeout for the menu.[1]
Disclaimer: I have no idea how Devuan's bootloader is configured big_smile
#3 2019-04-03 16:17:52
Spaceman Spiff
Re: No Grub menu
Thanks, will try your suggestions
#4 2019-04-03 18:19:05
Spaceman Spiff
Re: No Grub menu
It looks okay.
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
GRUB_CMDLINE_LINUX=""
#5 2019-04-03 19:17:49
Re: No Grub menu
So is your machine actually booting with GRUB?
Install the boot-info-script package and run
Post the output here (using code tags) if you don't understand how to interpret it.
EDIT: corrected name of package.
#6 2019-04-05 18:01:44
Spaceman Spiff
Re: No Grub menu
efibotmgr out
BootCurrent: 0003
Timeout: 2 seconds
BootOrder: 0003,0008,0002,0001,0009,0006,0007,0005,0004,0000
Boot0000* refracta
Boot0001* USB Floppy/CD
Boot0002* USB Hard Drive
Boot0003* devuan
Boot0004* MX16
Boot0005* Salix-Xfce-14.2
Boot0006* USB Floppy/CD
Boot0007* Hard Drive
Boot0008* ATAPI CD-ROM Drive
Boot0009* CD/DVD Drive
boot info script.
P.S. It doesn't work with MX or Salix (elilo) either. Refracta is no longer on the drive, and didn't work as well.
                  Boot Info Script 0.61      [1 April 2012]
============================= Boot Info Summary: ===============================
 => No boot loader is installed in the MBR of /dev/sda.
sda1: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Windows Vista/7: NTFS
    Boot sector info:  No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:
sda2: __________________________________________________________________________
    File system:       vfat
    Boot sector type:  Unknown
    Operating System:
    Boot files:        /efi/Boot/bootx64.efi /efi/devuan/grubx64.efi
                       /efi/MX16/grubx64.efi /efi/refracta/grubx64.efi
                       /efi/Salix-Xfce-14.2/elilo.efi
sda3: __________________________________________________________________________
    File system:
    Boot sector type:  -
    Boot sector info:
    Mounting failed:   mount: unknown filesystem type ''
sda4: __________________________________________________________________________
    File system:       ntfs
    Operating System:
    Boot files:        /bootmgr /Boot/BCD /Windows/System32/winload.exe
sda5: __________________________________________________________________________
    File system:       ntfs
    Operating System:
    Boot files:
sda6: __________________________________________________________________________
    File system:       ntfs
    Operating System:
    Boot files:        /bootmgr /boot/bcd
sda7: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:  Devuan GNU/Linux ascii
    Boot files:        /boot/grub/grub.cfg /etc/fstab
sda8: __________________________________________________________________________
    File system:       swap
    Boot sector type:  -
    Boot sector info:
sda9: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:
    Boot files:
sda10: _________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:  [1;32mWelcome to [1;37mMX
                       16.1 (Metamorphosis) 64-bit[1;32m! Powered by
                       [1;37mDebian[1;32m.[0m
sda11: _________________________________________________________________________
    File system:       swap
    Boot sector type:  -
    Boot sector info:
sda12: _________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:
    Boot files:
sda13: _________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:  Slackware 14.2
    Boot files:        /etc/fstab
sda14: _________________________________________________________________________
    File system:       swap
    Boot sector type:  -
    Boot sector info:
sda15: _________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:
    Boot files:
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 1.4 TiB, 1500301910016 bytes, 2930277168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Partition  Boot  Start Sector    End Sector  # of Sectors  Id System
/dev/sda1                   1 2,930,277,167 2,930,277,167  ee GPT
GUID Partition Table detected.
Partition    Start Sector    End Sector  # of Sectors System
/dev/sda1           2,048     2,097,151     2,095,104 Windows Recovery Environment (Windows)
/dev/sda2       2,097,152     2,834,431       737,280 EFI System partition
/dev/sda3       2,834,432     3,096,575       262,144 Microsoft Reserved Partition (Windows)
/dev/sda4       3,096,576 2,471,393,279 2,468,296,704 Data partition (Windows/Linux)
/dev/sda5   2,892,105,728 2,893,027,327       921,600 Windows Recovery Environment (Windows)
/dev/sda6   2,893,027,328 2,930,277,134    37,249,807 Data partition (Windows/Linux)
/dev/sda7   2,471,393,280 2,520,221,695    48,828,416 Data partition (Linux)
/dev/sda8   2,520,221,696 2,529,986,559     9,764,864 Swap partition (Linux)
/dev/sda9   2,529,986,560 2,569,048,063    39,061,504 Data partition (Linux)
/dev/sda10  2,569,048,064 2,621,382,655    52,334,592 Data partition (Linux)
/dev/sda11  2,621,382,656 2,633,836,543    12,453,888 Swap partition (Linux)
/dev/sda12  2,633,836,544 2,675,159,039    41,322,496 -
/dev/sda13  2,675,159,040 2,716,813,311    41,654,272 Data partition (Linux)
/dev/sda14  2,716,813,312 2,729,435,135    12,621,824 Swap partition (Linux)
/dev/sda15  2,729,435,136 2,774,982,655    45,547,520 Data partition (Linux)
"blkid" output: ________________________________________________________________
Device           UUID                                   TYPE       LABEL
/dev/sda1        BA6AC7476AC6FEDF                       ntfs       Windows RE tools
/dev/sda10       d28eca5f-efe5-44a6-bd83-2b996c50ef13   ext4       rootMX16
/dev/sda11       35245d32-a9da-47ab-ae28-059a2c41a5eb   swap
/dev/sda12       41061a64-09eb-4757-8c45-23d6ba24a1ac   ext4       homeMX
/dev/sda13       66d7d661-67ed-4e46-b8fe-f052f49ddb66   ext4
/dev/sda14       c74f2e82-f910-474c-a73f-46238adb38aa   swap
/dev/sda15       8fde9687-00dc-409b-9827-4ee57d612025   ext4
/dev/sda2        42B8-E86A                              vfat       SYSTEM
/dev/sda3
/dev/sda4        A2DAC1D3DAC1A43F                       ntfs       Windows
/dev/sda5        CAB40444B404360B                       ntfs
/dev/sda6        D272C2AC72C2951F                       ntfs       Recovery Image
/dev/sda7        e3c7b338-1084-4637-b18c-1c8dfba13284   ext4       Devuan-root
/dev/sda8        e9fd888c-c2c2-4244-bfcf-ebdb9e82146b   swap
/dev/sda9        43b819a7-5c83-4325-ab2d-86109aa24b60   ext4       Devuan-home
/dev/sr0         2018-06-06-14-35-28-00                 iso9660    devuan_2.0.0_amd64_1
================================ Mount points: =================================
Device           Mount_Point              Type       Options
/dev/sda2        /boot/efi                vfat       (rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
/dev/sda7        /                        ext4       (rw,relatime,errors=remount-ro,data=ordered)
/dev/sda9        /home                    ext4       (rw,relatime,data=ordered)
=========================== sda7/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
  set have_grubenv=true
  load_env
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
if [ x$feature_default_font_path = xy ] ; then
   font=unicode
else
insmod part_gpt
insmod ext2
set root='hd0,gpt7'
if [ x$feature_platform_search_hint = xy ]; then
  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt7 --hint-efi=hd0,gpt7 --hint-baremetal=ahci0,gpt7  e3c7b338-1084-4637-b18c-1c8dfba13284
else
  search --no-floppy --fs-uuid --set=root e3c7b338-1084-4637-b18c-1c8dfba13284
fi
    font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
  set locale_dir=$prefix/locale
  set lang=en_US
  insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
  set timeout=30
else
  if [ x$feature_timeout_style = xy ] ; then
    set timeout_style=menu
    set timeout=5
  # Fallback normal timeout code in case the timeout_style feature is
  # unavailable.
  else
    set timeout=5
  fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=cyan/blue
set menu_color_highlight=white/blue
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
	set gfxpayload="${1}"
set linux_gfx_mode=
export linux_gfx_mode
menuentry 'Devuan GNU/Linux' --class devuan --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-e3c7b338-1084-4637-b18c-1c8dfba13284' {
	load_video
	insmod gzio
	if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt7'
	else
	fi
	echo	'Loading Linux 4.9.0-6-amd64 ...'
	linux	/boot/vmlinuz-4.9.0-6-amd64 root=UUID=e3c7b338-1084-4637-b18c-1c8dfba13284 ro  quiet
	echo	'Loading initial ramdisk ...'
	initrd	/boot/initrd.img-4.9.0-6-amd64
submenu 'Advanced options for Devuan GNU/Linux' $menuentry_id_option 'gnulinux-advanced-e3c7b338-1084-4637-b18c-1c8dfba13284' {
	menuentry 'Devuan GNU/Linux, with Linux 4.9.0-6-amd64' --class devuan --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.9.0-6-amd64-advanced-e3c7b338-1084-4637-b18c-1c8dfba13284' {
		load_video
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
	menuentry 'Devuan GNU/Linux, with Linux 4.9.0-6-amd64 (recovery mode)' --class devuan --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.9.0-6-amd64-recovery-e3c7b338-1084-4637-b18c-1c8dfba13284' {
		load_video
		insmod gzio
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
		linux	/boot/vmlinuz-4.9.0-6-amd64 root=UUID=e3c7b338-1084-4637-b18c-1c8dfba13284 ro single
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'MX-16.1 Metamorphosis (16.1) (on /dev/sda10)' --class mx --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-d28eca5f-efe5-44a6-bd83-2b996c50ef13' {
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt10'
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt10 --hint-efi=hd0,gpt10 --hint-baremetal=ahci0,gpt10  d28eca5f-efe5-44a6-bd83-2b996c50ef13
	else
	  search --no-floppy --fs-uuid --set=root d28eca5f-efe5-44a6-bd83-2b996c50ef13
	fi
	linux /boot/vmlinuz-4.7.0-0.bpo.1-amd64 root=UUID=d28eca5f-efe5-44a6-bd83-2b996c50ef13 ro zswap.zpool=zsmalloc BOOT_IMAGE=/antiX/vmlinuz quiet
	initrd /boot/initrd.img-4.7.0-0.bpo.1-amd64
submenu 'Advanced options for MX-16.1 Metamorphosis (16.1) (on /dev/sda10)' $menuentry_id_option 'osprober-gnulinux-advanced-d28eca5f-efe5-44a6-bd83-2b996c50ef13' {
	menuentry 'MX-16.1 Metamorphosis (on /dev/sda10)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.7.0-0.bpo.1-amd64--d28eca5f-efe5-44a6-bd83-2b996c50ef13' {
		insmod part_gpt
		insmod ext2
		else
		fi
	menuentry 'MX-16.1 Metamorphosis, with Linux 4.7.0-0.bpo.1-amd64 (on /dev/sda10)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.7.0-0.bpo.1-amd64--d28eca5f-efe5-44a6-bd83-2b996c50ef13' {
		insmod part_gpt
		insmod ext2
		else
		fi
	menuentry 'MX-16.1 Metamorphosis, with Linux 4.7.0-0.bpo.1-amd64 (sysvinit) (on /dev/sda10)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.7.0-0.bpo.1-amd64--d28eca5f-efe5-44a6-bd83-2b996c50ef13' {
		insmod part_gpt
		insmod ext2
		else
		fi
		linux /boot/vmlinuz-4.7.0-0.bpo.1-amd64 root=UUID=d28eca5f-efe5-44a6-bd83-2b996c50ef13 ro zswap.zpool=zsmalloc BOOT_IMAGE=/antiX/vmlinuz quiet init=/lib/sysvinit/init
	menuentry 'MX-16.1 Metamorphosis, with Linux 4.7.0-0.bpo.1-amd64 (systemd) (on /dev/sda10)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.7.0-0.bpo.1-amd64--d28eca5f-efe5-44a6-bd83-2b996c50ef13' {
		insmod part_gpt
		insmod ext2
		else
		fi
		linux /boot/vmlinuz-4.7.0-0.bpo.1-amd64 root=UUID=d28eca5f-efe5-44a6-bd83-2b996c50ef13 ro zswap.zpool=zsmalloc BOOT_IMAGE=/antiX/vmlinuz quiet init=/lib/systemd/systemd
menuentry 'Refracta GNU/Linux (9.0) (on /dev/sda13)' --class refracta --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-bce1dbf2-a9ec-48ae-80b2-dd78fdb15d94' {
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt13'
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt13 --hint-efi=hd0,gpt13 --hint-baremetal=ahci0,gpt13  bce1dbf2-a9ec-48ae-80b2-dd78fdb15d94
	else
	  search --no-floppy --fs-uuid --set=root bce1dbf2-a9ec-48ae-80b2-dd78fdb15d94
	fi
	linux /boot/vmlinuz-4.9.0-8-amd64 root=UUID=bce1dbf2-a9ec-48ae-80b2-dd78fdb15d94 ro
	initrd /boot/initrd.img-4.9.0-8-amd64
submenu 'Advanced options for Refracta GNU/Linux (9.0) (on /dev/sda13)' $menuentry_id_option 'osprober-gnulinux-advanced-bce1dbf2-a9ec-48ae-80b2-dd78fdb15d94' {
	menuentry 'Refracta GNU/Linux (on /dev/sda13)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.9.0-8-amd64--bce1dbf2-a9ec-48ae-80b2-dd78fdb15d94' {
		insmod part_gpt
		insmod ext2
		else
		fi
	menuentry 'Refracta GNU/Linux, with Linux 4.9.0-8-amd64 (on /dev/sda13)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.9.0-8-amd64--bce1dbf2-a9ec-48ae-80b2-dd78fdb15d94' {
		insmod part_gpt
		insmod ext2
		else
		fi
	menuentry 'Refracta GNU/Linux, with Linux 4.9.0-8-amd64 (recovery mode) (on /dev/sda13)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.9.0-8-amd64-root=UUID=bce1dbf2-a9ec-48ae-80b2-dd78fdb15d94 ro single-bce1dbf2-a9ec-48ae-80b2-dd78fdb15d94' {
		insmod part_gpt
		insmod ext2
		else
		fi
		linux /boot/vmlinuz-4.9.0-8-amd64 root=UUID=bce1dbf2-a9ec-48ae-80b2-dd78fdb15d94 ro single
menuentry 'Windows Boot Manager (on /dev/sda2)' --class windows --class os $menuentry_id_option 'osprober-efi-42B8-E86A' {
	insmod part_gpt
	insmod fat
	set root='hd0,gpt2'
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt2 --hint-efi=hd0,gpt2 --hint-baremetal=ahci0,gpt2  42B8-E86A
	else
	  search --no-floppy --fs-uuid --set=root 42B8-E86A
	fi
	chainloader /EFI/Microsoft/Boot/bootmgfw.efi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
menuentry 'System setup' $menuentry_id_option 'uefi-firmware' {
	fwsetup
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sda7/etc/fstab: ================================
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda7 during installation
UUID=e3c7b338-1084-4637-b18c-1c8dfba13284 /               ext4    errors=remount-ro 0       1
# /boot/efi was on /dev/sda2 during installation
UUID=42B8-E86A  /boot/efi       vfat    umask=0077      0       1
# /home was on /dev/sda9 during installation
UUID=43b819a7-5c83-4325-ab2d-86109aa24b60 /home           ext4    defaults        0       2
# swap was on /dev/sda11 during installation
UUID=35245d32-a9da-47ab-ae28-059a2c41a5eb none            swap    sw              0       0
# swap was on /dev/sda14 during installation
UUID=c74f2e82-f910-474c-a73f-46238adb38aa none            swap    sw              0       0
# swap was on /dev/sda8 during installation
UUID=29fd684e-d6fa-458b-8c57-bb60517c232e none            swap    sw              0       0
/dev/sr0        /media/cdrom0   udf,iso9660 user,noauto     0       0
=================== sda7: Location of files loaded by Grub: ====================
           GiB - GB             File                                 Fragment(s)
========================== sda10/boot/grub/grub.cfg: ===========================
  load_env
fi
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="0"
fi
else
fi
  set boot_once=true
fi
  fi
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
   font=unicode
else
insmod part_gpt
insmod ext2
else
fi
fi
  set gfxmode=auto
  load_video
  insmod gfxterm
  set lang=en_US
  insmod gettext
fi
insmod part_gpt
insmod ext2
else
fi
insmod png
background_image -m stretch /usr/local/share/backgrounds/MX16/grub/kingfisher.png
  set timeout=-1
else
    set timeout=5
  # unavailable.
  else
    set timeout=5
  fi
fi
insmod part_gpt
insmod ext2
else
fi
insmod png
if background_image /usr/local/share/backgrounds/MX16/grub/kingfisher.png; then
  true
else
fi
function gfxmode {
set linux_gfx_mode=
menuentry 'MX-16.1 Metamorphosis' --class mx_16_1 --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-d28eca5f-efe5-44a6-bd83-2b996c50ef13' {
	load_video
	insmod gzio
	insmod part_gpt
	insmod ext2
	else
	fi
	echo	'Loading Linux 4.7.0-0.bpo.1-amd64 ...'
submenu 'Advanced options for MX-16.1 Metamorphosis' $menuentry_id_option 'gnulinux-advanced-d28eca5f-efe5-44a6-bd83-2b996c50ef13' {
	menuentry 'MX-16.1 Metamorphosis, with Linux 4.7.0-0.bpo.1-amd64' --class mx_16_1 --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.7.0-0.bpo.1-amd64-advanced-d28eca5f-efe5-44a6-bd83-2b996c50ef13' {
		load_video
		insmod gzio
		insmod part_gpt
		insmod ext2
		else
		fi
	menuentry 'MX-16.1 Metamorphosis, with Linux 4.7.0-0.bpo.1-amd64 (sysvinit)' --class mx_16_1 --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.7.0-0.bpo.1-amd64-init-sysvinit-d28eca5f-efe5-44a6-bd83-2b996c50ef13' {
		load_video
		insmod gzio
		insmod part_gpt
		insmod ext2
		else
		fi
	menuentry 'MX-16.1 Metamorphosis, with Linux 4.7.0-0.bpo.1-amd64 (systemd)' --class mx_16_1 --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.7.0-0.bpo.1-amd64-init-systemd-d28eca5f-efe5-44a6-bd83-2b996c50ef13' {
		load_video
		insmod gzio
		insmod part_gpt
		insmod ext2
		else
		fi
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry "Memory test (memtest86+)" {
	insmod part_gpt
	insmod ext2
	else
	fi
	linux16	/boot/memtest86+.bin
### END /etc/grub.d/20_memtest86+ ###
menuentry 'Refracta GNU/Linux (9.0) (on /dev/sda13)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-bce1dbf2-a9ec-48ae-80b2-dd78fdb15d94' {
	insmod part_gpt
	insmod ext2
	else
	fi
		insmod part_gpt
		insmod ext2
		else
		fi
		insmod part_gpt
		insmod ext2
		else
		fi
		insmod part_gpt
		insmod ext2
		else
		fi
menuentry 'Debian GNU/Linux (9) (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-6ccbd589-c365-4730-b05f-0fd29123b69d' {
	insmod part_gpt
	insmod ext2
	set root='hd0,gpt7'
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt7 --hint-efi=hd0,gpt7 --hint-baremetal=ahci0,gpt7  6ccbd589-c365-4730-b05f-0fd29123b69d
	else
	  search --no-floppy --fs-uuid --set=root 6ccbd589-c365-4730-b05f-0fd29123b69d
	fi
	linux /boot/vmlinuz-4.9.0-8-amd64 root=UUID=6ccbd589-c365-4730-b05f-0fd29123b69d ro quiet
submenu 'Advanced options for Debian GNU/Linux (9) (on /dev/sda7)' $menuentry_id_option 'osprober-gnulinux-advanced-6ccbd589-c365-4730-b05f-0fd29123b69d' {
	menuentry 'Devuan GNU/Linux (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.9.0-8-amd64--6ccbd589-c365-4730-b05f-0fd29123b69d' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
	menuentry 'Devuan GNU/Linux, with Linux 4.9.0-8-amd64 (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.9.0-8-amd64--6ccbd589-c365-4730-b05f-0fd29123b69d' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
	menuentry 'Devuan GNU/Linux, with Linux 4.9.0-8-amd64 (recovery mode) (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.9.0-8-amd64-root=UUID=6ccbd589-c365-4730-b05f-0fd29123b69d ro single-6ccbd589-c365-4730-b05f-0fd29123b69d' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
		linux /boot/vmlinuz-4.9.0-8-amd64 root=UUID=6ccbd589-c365-4730-b05f-0fd29123b69d ro single
	menuentry 'Devuan GNU/Linux, with Linux 4.9.0-6-amd64 (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.9.0-6-amd64--6ccbd589-c365-4730-b05f-0fd29123b69d' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
		linux /boot/vmlinuz-4.9.0-6-amd64 root=UUID=6ccbd589-c365-4730-b05f-0fd29123b69d ro quiet
	menuentry 'Devuan GNU/Linux, with Linux 4.9.0-6-amd64 (recovery mode) (on /dev/sda7)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-4.9.0-6-amd64-root=UUID=6ccbd589-c365-4730-b05f-0fd29123b69d ro single-6ccbd589-c365-4730-b05f-0fd29123b69d' {
		insmod part_gpt
		insmod ext2
		set root='hd0,gpt7'
		else
		fi
		linux /boot/vmlinuz-4.9.0-6-amd64 root=UUID=6ccbd589-c365-4730-b05f-0fd29123b69d ro single
	fwsetup
fi
=============================== sda10/etc/fstab: ===============================
# Pluggable devices are handled by uDev, they are not in fstab
/dev/sda10 / auto defaults,noatime 1 1
/dev/sda12 /home auto defaults,noatime 1 2
# Added by make-fstab /dev/sda8
UUID=e323ac15-8f84-429d-bcdd-3dbedc53cbf8  swap                                        swap       defaults                        0 0
# Added by make-fstab /dev/sda11
UUID=036b8dc1-4f02-4b0b-a8c9-bb7c8be48c2f  swap                                        swap       defaults                        0 0
# Added by make-fstab /dev/sda14  label=/swap
UUID=d0e493b0-b1fd-4267-9b99-6640091bb7c9  swap                                        swap       defaults                        0 0
=================== sda10: Location of files loaded by Grub: ===================
=============================== sda13/etc/fstab: ===============================
/dev/sda8        swap             swap        defaults         0   0
/dev/sda13       /                ext4        defaults         1   1
/dev/sda15       /home            ext4        defaults         1   2
/dev/sda2        /boot/efi        vfat        defaults         1   0
#/dev/cdrom      /mnt/cdrom       auto        noauto,owner,ro,comment=x-gvfs-show 0   0
/dev/fd0         /mnt/floppy      auto        noauto,users,rw,umask=00 0   0
devpts           /dev/pts         devpts      gid=5,mode=620   0   0
proc             /proc            proc        defaults         0   0
tmpfs            /dev/shm         tmpfs       defaults         0   0
=================== sda13: Location of files loaded by Grub: ===================
======================== Unknown MBRs/Boot Sectors/etc: ========================
Unknown GPT Partiton Type
e1c73a93b42e134fb8440e14e2aef915
Unknown BootLoader on sda2
00000000  eb 58 90 4d 53 44 4f 53  35 2e 30 00 02 08 6e 1a  |.X.MSDOS5.0...n.|
00000010  02 00 00 00 00 f8 00 00  3f 00 ff 00 00 00 20 00  |........?..... .|
00000020  00 40 0b 00 c9 02 00 00  00 00 00 00 02 00 00 00  |.@..............|
00000030  01 00 06 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00000040  80 01 29 6a e8 b8 42 4e  4f 20 4e 41 4d 45 20 20  |..)j..BNO NAME  |
00000050  20 20 46 41 54 33 32 20  20 20 33 c9 8e d1 bc f4  |  FAT32   3.....|
00000060  7b 8e c1 8e d9 bd 00 7c  88 56 40 88 4e 02 8a 56  |{......|.V@.N..V|
00000070  40 b4 41 bb aa 55 cd 13  72 10 81 fb 55 aa 75 0a  |@.A..U..r...U.u.|
00000080  f6 c1 01 74 05 fe 46 02  eb 2d 8a 56 40 b4 08 cd  |...t..F..-.V@...|
00000090  13 73 05 b9 ff ff 8a f1  66 0f b6 c6 40 66 0f b6  |.s......f...@f..|
000000a0  d1 80 e2 3f f7 e2 86 cd  c0 ed 06 41 66 0f b7 c9  |...?.......Af...|
000000b0  66 f7 e1 66 89 46 f8 83  7e 16 00 75 39 83 7e 2a  |f..f.F..~..u9.~*|
000000c0  00 77 33 66 8b 46 1c 66  83 c0 0c bb 00 80 b9 01  |.w3f.F.f........|
000000d0  00 e8 2c 00 e9 a8 03 a1  f8 7d 80 c4 7c 8b f0 ac  |..,......}..|...|
000000e0  84 c0 74 17 3c ff 74 09  b4 0e bb 07 00 cd 10 eb  |..t.<.t.........|
000000f0  ee a1 fa 7d eb e4 a1 7d  80 eb df 98 cd 16 cd 19  |...}...}........|
00000100  66 60 80 7e 02 00 0f 84  20 00 66 6a 00 66 50 06  |f`.~.... .fj.fP.|
00000110  53 66 68 10 00 01 00 b4  42 8a 56 40 8b f4 cd 13  |Sfh.....B.V@....|
00000120  66 58 66 58 66 58 66 58  eb 33 66 3b 46 f8 72 03  |fXfXfXfX.3f;F.r.|
00000130  f9 eb 2a 66 33 d2 66 0f  b7 4e 18 66 f7 f1 fe c2  |..*f3.f..N.f....|
00000140  8a ca 66 8b d0 66 c1 ea  10 f7 76 1a 86 d6 8a 56  |..f..f....v....V|
00000150  40 8a e8 c0 e4 06 0a cc  b8 01 02 cd 13 66 61 0f  |@............fa.|
00000160  82 74 ff 81 c3 00 02 66  40 49 75 94 c3 42 4f 4f  |.t.....f@Iu..BOO|
00000170  54 4d 47 52 20 20 20 20  00 00 00 00 00 00 00 00  |TMGR    ........|
00000180  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
000001a0  00 00 00 00 00 00 00 00  00 00 00 00 0d 0a 44 69  |..............Di|
000001b0  73 6b 20 65 72 72 6f 72  ff 0d 0a 50 72 65 73 73  |sk error...Press|
000001c0  20 61 6e 79 20 6b 65 79  20 74 6f 20 72 65 73 74  | any key to rest|
000001d0  61 72 74 0d 0a 00 00 00  00 00 00 00 00 00 00 00  |art.............|
000001e0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
000001f0  00 00 00 00 00 00 00 00  ac 01 b9 01 00 00 55 aa  |..............U.|
00000200
=============================== StdErr Messages: ===============================
cat: /tmp/BootInfo-lEOwPwjL/Tmp_Log: No such file or directory
#7 2019-04-05 18:16:02
Re: No Grub menu
Please edit your post and use code tags for the command output, it makes it *much* more readable and easier to scroll through.
Use the "Quote" button on this post to see how I do this:
This text is in code tags
(But don't submit it.)
#8 2019-04-05 18:35:46
Re: No Grub menu
Can we also see
efibootmgr -v
find /boot/efi
#9 2019-04-05 23:08:37
Spaceman Spiff
Re: No Grub menu
Sorry. Fixed it.
 BootCurrent: 0003
Timeout: 2 seconds
Boot0000* refracta	VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0001* USB Floppy/CD	VenMedia(b6fef66f-1495-4584-a836-3492d1984a8d,0500000001)..BO
Boot0002* USB Hard Drive	VenMedia(b6fef66f-1495-4584-a836-3492d1984a8d,0200000001)..BO
Boot0003* devuan	HD(2,GPT,3498b6b4-3379-424a-a524-5c4380f3ced2,0x200000,0xb4000)/File(\EFI\devuan\grubx64.efi)
Boot0004* MX16	VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0005* Salix-Xfce-14.2	VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0006* USB Floppy/CD	VenMedia(b6fef66f-1495-4584-a836-3492d1984a8d,0500000000)..BO
Boot0007* Hard Drive	BBS(HD,,0x0)..GO..NO........o.S.T.1.5.0.0.D.M.0.0.3.-.9.Y.N.1.6.G....................A...........................>..Gd-.;.A..MQ..L.1.W.1.E.C.5.V.7. . . . . . . . . . . . ........BO
Boot0008* ATAPI CD-ROM Drive	VenMedia(b6fef66f-1495-4584-a836-3492d1984a8d,0300000001)..BO
Boot0009* CD/DVD Drive 	BBS(CDROM,,0x0)..GO..NO........o.h.p. . . . . . .D.V.D.-.R.A.M. .G.H.A.3.N....................A...........................>..Gd-.;.A..MQ..L.1.3.C.7.0.D.5.0.2.5. .3. . . . . . . . ........BO
 /boot/efi
/boot/efi/SYSTEM
/boot/efi/EFI
/boot/efi/EFI/Microsoft
/boot/efi/EFI/Microsoft/Boot
/boot/efi/EFI/Microsoft/Boot/bg-BG
/boot/efi/EFI/Microsoft/Boot/bg-BG/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/bg-BG/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/cs-CZ
/boot/efi/EFI/Microsoft/Boot/cs-CZ/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/cs-CZ/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/cs-CZ/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/da-DK
/boot/efi/EFI/Microsoft/Boot/da-DK/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/da-DK/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/da-DK/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/de-DE
/boot/efi/EFI/Microsoft/Boot/de-DE/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/de-DE/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/de-DE/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/el-GR
/boot/efi/EFI/Microsoft/Boot/el-GR/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/el-GR/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/el-GR/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/en-GB
/boot/efi/EFI/Microsoft/Boot/en-GB/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/en-GB/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/en-US
/boot/efi/EFI/Microsoft/Boot/en-US/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/en-US/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/en-US/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/es-ES
/boot/efi/EFI/Microsoft/Boot/es-ES/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/es-ES/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/es-ES/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/et-EE
/boot/efi/EFI/Microsoft/Boot/et-EE/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/et-EE/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/fi-FI
/boot/efi/EFI/Microsoft/Boot/fi-FI/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/fi-FI/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/fi-FI/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/fr-FR
/boot/efi/EFI/Microsoft/Boot/fr-FR/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/fr-FR/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/fr-FR/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/hr-HR
/boot/efi/EFI/Microsoft/Boot/hr-HR/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/hr-HR/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/hu-HU
/boot/efi/EFI/Microsoft/Boot/hu-HU/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/hu-HU/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/hu-HU/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/it-IT
/boot/efi/EFI/Microsoft/Boot/it-IT/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/it-IT/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/it-IT/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/ja-JP
/boot/efi/EFI/Microsoft/Boot/ja-JP/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/ja-JP/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/ja-JP/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/ko-KR
/boot/efi/EFI/Microsoft/Boot/ko-KR/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/ko-KR/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/ko-KR/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/lt-LT
/boot/efi/EFI/Microsoft/Boot/lt-LT/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/lt-LT/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/lv-LV
/boot/efi/EFI/Microsoft/Boot/lv-LV/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/lv-LV/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/nb-NO
/boot/efi/EFI/Microsoft/Boot/nb-NO/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/nb-NO/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/nb-NO/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/nl-NL
/boot/efi/EFI/Microsoft/Boot/nl-NL/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/nl-NL/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/nl-NL/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/pl-PL
/boot/efi/EFI/Microsoft/Boot/pl-PL/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/pl-PL/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/pl-PL/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/pt-BR
/boot/efi/EFI/Microsoft/Boot/pt-BR/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/pt-BR/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/pt-BR/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/pt-PT
/boot/efi/EFI/Microsoft/Boot/pt-PT/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/pt-PT/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/pt-PT/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/qps-ploc
/boot/efi/EFI/Microsoft/Boot/qps-ploc/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/qps-ploc/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/qps-ploc/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/ro-RO
/boot/efi/EFI/Microsoft/Boot/ro-RO/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/ro-RO/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/ru-RU
/boot/efi/EFI/Microsoft/Boot/ru-RU/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/ru-RU/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/ru-RU/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/sk-SK
/boot/efi/EFI/Microsoft/Boot/sk-SK/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/sk-SK/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/sl-SI
/boot/efi/EFI/Microsoft/Boot/sl-SI/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/sl-SI/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/sr-Latn-CS
/boot/efi/EFI/Microsoft/Boot/sr-Latn-CS/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/sr-Latn-CS/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/sv-SE
/boot/efi/EFI/Microsoft/Boot/sv-SE/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/sv-SE/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/sv-SE/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/tr-TR
/boot/efi/EFI/Microsoft/Boot/tr-TR/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/tr-TR/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/tr-TR/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/uk-UA
/boot/efi/EFI/Microsoft/Boot/uk-UA/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/uk-UA/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/zh-CN
/boot/efi/EFI/Microsoft/Boot/zh-CN/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/zh-CN/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/zh-CN/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/zh-HK
/boot/efi/EFI/Microsoft/Boot/zh-HK/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/zh-HK/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/zh-HK/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/zh-TW
/boot/efi/EFI/Microsoft/Boot/zh-TW/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/zh-TW/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/zh-TW/memtest.efi.mui
/boot/efi/EFI/Microsoft/Boot/BOOTSTAT.DAT
/boot/efi/EFI/Microsoft/Boot/Fonts
/boot/efi/EFI/Microsoft/Boot/Fonts/chs_boot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/cht_boot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/jpn_boot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/kor_boot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/malgunn_boot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/malgun_boot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/meiryon_boot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/meiryo_boot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/msjhn_boot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/msjh_boot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/msyhn_boot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/msyh_boot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/segmono_boot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/segoen_slboot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/segoe_slboot.ttf
/boot/efi/EFI/Microsoft/Boot/Fonts/wgl4_boot.ttf
/boot/efi/EFI/Microsoft/Boot/Resources
/boot/efi/EFI/Microsoft/Boot/Resources/en-US
/boot/efi/EFI/Microsoft/Boot/Resources/en-US/bootres.dll.mui
/boot/efi/EFI/Microsoft/Boot/Resources/bootres.dll
/boot/efi/EFI/Microsoft/Boot/BCD
/boot/efi/EFI/Microsoft/Boot/BCD.LOG
/boot/efi/EFI/Microsoft/Boot/BCD.LOG1
/boot/efi/EFI/Microsoft/Boot/BCD.LOG2
/boot/efi/EFI/Microsoft/Boot/sr-Latn-RS
/boot/efi/EFI/Microsoft/Boot/sr-Latn-RS/bootmgfw.efi.mui
/boot/efi/EFI/Microsoft/Boot/sr-Latn-RS/bootmgr.efi.mui
/boot/efi/EFI/Microsoft/Boot/boot.stl
/boot/efi/EFI/Microsoft/Boot/bootmgfw.efi
/boot/efi/EFI/Microsoft/Boot/bootmgr.efi
/boot/efi/EFI/Microsoft/Boot/memtest.efi
/boot/efi/EFI/Boot
/boot/efi/EFI/Boot/bootx64.efi
/boot/efi/EFI/devuan
/boot/efi/EFI/devuan/grubx64.efi
/boot/efi/EFI/MX16
/boot/efi/EFI/MX16/grubx64.efi
/boot/efi/EFI/HP
/boot/efi/EFI/HP/BIOS
/boot/efi/EFI/HP/BIOS/Current
/boot/efi/EFI/HP/BIOS/Current/JA2_8030.BIN
/boot/efi/EFI/HP/BIOS/New
/boot/efi/EFI/HP/BIOS/Previous
/boot/efi/EFI/HP/BiosUpdate
/boot/efi/EFI/HP/BiosUpdate/CryptRSA.efi
/boot/efi/EFI/HP/BiosUpdate/CryptRSA32.efi
/boot/efi/EFI/HP/BiosUpdate/HpBiosUpdate.efi
/boot/efi/EFI/HP/BiosUpdate/HpBiosUpdate.s09
/boot/efi/EFI/HP/BiosUpdate/HpBiosUpdate.s12
/boot/efi/EFI/HP/BiosUpdate/HpBiosUpdate.sig
/boot/efi/EFI/HP/BiosUpdate/HpBiosUpdate32.efi
/boot/efi/EFI/HP/BiosUpdate/HpBiosUpdate32.s09
/boot/efi/EFI/HP/BiosUpdate/HpBiosUpdate32.s12
/boot/efi/EFI/HP/BiosUpdate/HpBiosUpdate32.sig
/boot/efi/EFI/HP/BiosUpdate/HpBiosUpdate.log
/boot/efi/EFI/HP/SystemDiags
/boot/efi/EFI/HP/SystemDiags/!12345678901.txt
/boot/efi/EFI/HP/SystemDiags/!123456789010.txt
/boot/efi/EFI/HP/SystemDiags/!123456789011.txt
/boot/efi/EFI/HP/SystemDiags/!123456789012.txt
/boot/efi/EFI/HP/SystemDiags/!123456789013.txt
/boot/efi/EFI/HP/SystemDiags/!123456789014.txt
/boot/efi/EFI/HP/SystemDiags/!123456789015.txt
/boot/efi/EFI/HP/SystemDiags/!123456789016.txt
/boot/efi/EFI/HP/SystemDiags/!123456789017.txt
/boot/efi/EFI/HP/SystemDiags/!123456789018.txt
/boot/efi/EFI/HP/SystemDiags/!123456789019.txt
/boot/efi/EFI/HP/SystemDiags/!12345678902.txt
/boot/efi/EFI/HP/SystemDiags/!123456789020.txt
/boot/efi/EFI/HP/SystemDiags/!123456789021.txt
/boot/efi/EFI/HP/SystemDiags/!123456789022.txt
/boot/efi/EFI/HP/SystemDiags/!123456789023.txt
/boot/efi/EFI/HP/SystemDiags/!123456789024.txt
/boot/efi/EFI/HP/SystemDiags/!123456789025.txt
/boot/efi/EFI/HP/SystemDiags/!123456789026.txt
/boot/efi/EFI/HP/SystemDiags/!123456789027.txt
/boot/efi/EFI/HP/SystemDiags/!123456789028.txt
/boot/efi/EFI/HP/SystemDiags/!123456789029.txt
/boot/efi/EFI/HP/SystemDiags/!12345678903.txt
/boot/efi/EFI/HP/SystemDiags/!123456789030.txt
/boot/efi/EFI/HP/SystemDiags/!12345678904.txt
/boot/efi/EFI/HP/SystemDiags/!12345678905.txt
/boot/efi/EFI/HP/SystemDiags/!12345678906.txt
/boot/efi/EFI/HP/SystemDiags/!12345678907.txt
/boot/efi/EFI/HP/SystemDiags/!12345678908.txt
/boot/efi/EFI/HP/SystemDiags/!12345678909.txt
/boot/efi/EFI/HP/SystemDiags/CryptRSA.efi
/boot/efi/EFI/HP/SystemDiags/CryptRSA32.efi
/boot/efi/EFI/HP/SystemDiags/firewirediags.msg.xml
/boot/efi/EFI/HP/SystemDiags/FirewireDiags.udm
/boot/efi/EFI/HP/SystemDiags/FirewireDiags32.udm
/boot/efi/EFI/HP/SystemDiags/opticaldiags.msg.xml
/boot/efi/EFI/HP/SystemDiags/OpticalDiags.udm
/boot/efi/EFI/HP/SystemDiags/OpticalDiags32.udm
/boot/efi/EFI/HP/SystemDiags/SystemDiags.efi
/boot/efi/EFI/HP/SystemDiags/SystemDiags.s09
/boot/efi/EFI/HP/SystemDiags/SystemDiags.s12
/boot/efi/EFI/HP/SystemDiags/SystemDiags.sig
/boot/efi/EFI/HP/SystemDiags/SystemDiags32.efi
/boot/efi/EFI/HP/SystemDiags/SystemDiags32.s09
/boot/efi/EFI/HP/SystemDiags/SystemDiags32.s12
/boot/efi/EFI/HP/SystemDiags/SystemDiags32.sig
/boot/efi/EFI/HP/SystemDiags/usbdiags.msg.xml
/boot/efi/EFI/HP/SystemDiags/USBDiags.udm
/boot/efi/EFI/HP/SystemDiags/USBDiags32.udm
/boot/efi/EFI/HP/SystemDiags/VideoDiags.udm
/boot/efi/EFI/HP/SystemDiags/VideoDiags32.udm
/boot/efi/EFI/HP/SystemDiags/VideoMem.udm
/boot/efi/EFI/HP/SystemDiags/VideoMem32.udm
/boot/efi/EFI/HP/SystemRecovery
/boot/efi/EFI/HP/SystemRecovery/bootmgfw.efi
/boot/efi/EFI/HP/SystemRecovery/BCD
/boot/efi/EFI/HP/SystemRecovery/BCD.LOG
/boot/efi/EFI/HP/SystemRecovery/BCD.LOG1
/boot/efi/EFI/HP/SystemRecovery/BCD.LOG2
/boot/efi/EFI/refracta
/boot/efi/EFI/refracta/grubx64.efi
/boot/efi/EFI/Salix-Xfce-14.2
/boot/efi/EFI/Salix-Xfce-14.2/elilo.conf
/boot/efi/EFI/Salix-Xfce-14.2/elilo.efi
/boot/efi/EFI/Salix-Xfce-14.2/vmlinuz
/boot/efi/HP_TOOLS
/boot/efi/BOOTSECT.BAK
#10 2019-04-05 23:42:27
Re: No Grub menu
Thanks, that's better smile
So you are booting in UEFI mode using Devuan's grub.cfg, which has the timeout set to 5 seconds.
I don't know why you're not seeing the menu, it should appear for 5 seconds.
Is there a delay of about 5 seconds before the system boots?
Perhaps the selected graphics mode is incompatible with your system.
EDIT: try editing /etc/default/grub and replace
#GRUB_TERMINAL=console
with
(Remove the # symbol.)
Then save the file and run
update-grub
#11 2019-04-06 07:16:39
Spaceman Spiff
Re: No Grub menu
Done.
When I shut it down, it works. restart doesn't work.
It came up a couple of times before in text mode before, but they were the exception.
#12 2019-04-06 08:24:46
Re: No Grub menu
I'm not sure I understand you.
So if you shutdown the machine then you can see the GRUB menu when you start it up again?
But when you just reboot you can't see the menu, is that correct?
And to ask again: is there a 5 second delay before the system starts when you don't see the menu?
That GRUB_TERMINAL option only works for non-UEFI booting anyway so it was a poor suggestion (sorry).
What is your graphics hardware? Is it NVIDIA?
#13 2019-04-06 16:24:32
dxrobertson
Re: No Grub menu
In /etc/default/grub.
Maybe try setting GRUB_TIMEOUT to something ridiculous to see if its a timing problem:
GRUB_TIMEOUT=9
You can also prohibit the OS Prober, which would make a much simpler grub.cfg, may help in debugging:
GRUB_DISABLE_OS_PROBER="true"
I wonder if changing the GRUB_DEFAULT=0 to something else would change whats booted?
Did you post your full /etc/default/grub contents?
Dont forget to update grub if you do make any changes:
update-grub
#14 2019-04-06 16:36:18
Re: No Grub menu
Yes, it's here: https://dev1galaxy.org/viewtopic.php?pid=15271#p15271
Perhaps the OP could also try un-commenting the GRUB_GFXMODE line to set the resolution to 640x480
This should show the available framebuffer resolutions:
# apt install hwinfo
# hwinfo --framebuffer | grep 'Mode '
Try one of those if 640x480 isn't supported.
#15 2019-04-06 20:07:04
dxrobertson
Re: No Grub menu
I am thinking its video related as well.  Grub is probably "running", just not showing.
A simple test would be to hit the down arrow several times around when you think the grub menu should be displayed.  This would prohibit the default boot from taking off.
#16 2019-04-07 08:24:24
Spaceman Spiff
Re: No Grub menu
Yes that is correct. Grub shows up on cold start now. It is amd a8 apu with built in graphics
Will try other suggestions tomorrow if I get time.
#17 2019-04-07 17:18:52
Spaceman Spiff
Re: No Grub menu
It works on restart now, but it only has a one second clock even though timeout is set for 15.
First, I used hwinfo and set framebuffer to Mode 0x03d4: 1920x1080 (+7680), 24 bits, and then tried gfxmode. gfxmode lasted 15 seconds the first time but reverted back to one second.
#18 2019-04-07 19:18:25
Re: No Grub menu
That is very strange.
What if you set GRUB_TIMEOUT to "-1", is that honoured?
#19 2019-04-10 16:21:43
Spaceman Spiff
Re: No Grub menu
-1 Grub timeout works. Have not had one instance where it did not.
Strange thing, that is.
