#1 2019-02-18 17:57:54
SolidTrump
How does one install Firefox Quantum on Devuan? [SOLVED]
So I got the newest version of Firefox and it has been extracted from the tar file. But how to I make it installed as a program. I try opening Linux on other applications such as Discord for example but instead it opens Lynx (a command line browser).
#2 2019-02-18 18:38:53
Re: How does one install Firefox Quantum on Devuan? [SOLVED]
Extract the tar.gz to /tmp. Then do as root:
mv firefox /opt/firefox
Then create a starter on the desktop. Command points to /opt/firefox/firefox, as icon you can select an icon from /opt/firefox/browser/chrome/icons/default.
Rolf
#3 2019-02-18 21:37:15
AntoFox
this can help you:
http://hezeh.org/how-to-install-latest-firefox-on-linux
#4 2019-02-18 22:56:01
SolidTrump
Thanks to the two replies I fixed the issue. Thanks guys!
