#1 2016-08-21 22:36:47
Jaromil
d1g
restore desktop functionalies for: suspend, hibernate, switch-users, shutdown and restart
Upon installation of the default xfce4 desktop, buttons for suspend, hibernate, switch-users, shutdown and restart are not working. Solutions suggested on DNG here below:
Boruch:
The easy solution for suspend and hibernate is to create a pkla file i
n
folder /etc/polkit-1/localauthority/50-local.d with contents:
[Allow locally logged in members of group 'power' to put the hardware
in
suspend mode]
Identity=unix-user:*
Action=org.freedesktop.upower.suspend
ResultAny=no
ResultInactive=yes
ResultActive=yes
in
hibernate mode]
Action=org.freedesktop.upower.hibernate
ResultAny=no
ResultInactive=yes
ResultActive=yes
Golinux:
Installing upower and libupower-glib1 from the devuan repos got the
whole shebang working for me from the xfce panel and/or main menu.
Mitt:
(for Reboot and Shutdown) try these:
create /etc/polkit-1/localauthority/50-local.d/‎consolekit.pkla and wit
h the content:
[restart]
Action=org.freedesktop.consolekit.system.restart
ResultAny=yes
[stop]
Action=org.freedesktop.consolekit.system.stop
ResultAny=yes
________________________________________
Project: devuan-packages/policykit-1
Issue: #5
By: Jaromil
#2 2017-06-20 13:46:57
Re: restore desktop functionalies for: suspend, hibernate, switch-users, shutdown and restart
Where can I get a power group so I can add my user to it? I tried 'addgroup power && adduser user power' but that didn't fix the problem. (I didn't really expect it to.)
#3 2017-06-20 14:26:48
In case someone else gets the idea to try it, I'll list one more thing that did NOT work for me.
remove (purge) task-desktop and task-xfce-desktop
apt-get autoremove (removes 314 packages)
install task-desktop task-xfce-desktop and slim
#4 2017-06-20 16:31:40
One more time...
I compared package lists between my debian upgrade and the desktop-live. I removed and added packages to the upgraded system until the lists were the same (with the exception of non-free firmware and refracta tools.)  It still doesn't work.
I wish I had tried this months ago. Tell me what I'm missing, or we need to stop telling people that this works.
