#1 2018-11-09 18:14:00
basati
How do I create a configured raspberry image?
It has taken me a long time to configure and install the packages in an ASCII 2.0 raspi3
How can I do the reverse. TIt has taken me a long time to configure and install the packages in an ASCII 2.0 raspi3
How can I do the reverse. The official image is installed on a microSD. What I want is a microSD that is configured to convert it into an image that I can use in other microSDs.
Thankshe official image is installed on a microSD. What I want is a microSD that is configured to convert it into an image that I can use in other microSDs.
Thanks
Gora gu ta gutarrok
8=þ
#2 2018-11-10 16:33:12
Olle2
Re: How do I create a configured raspberry image?
Hi the files are available at https://files.devuan.org/devuan_ascii/embedded/ It seems that you ask for an image without extra packages. If not I have misunderstood your question. Good luck! Olle
#3 2018-11-10 17:56:52
I think that the arm-sdk toolkit should do what you want.  There are other flavors of SDK here if you want to explore further.
#4 2018-11-11 21:44:31
arnaiz
Have you tried dump with dd?
