#1 2018-11-03 08:30:45
spartrekus
Devuan for K6-2 - 64 MB RAM - 4.3 GB HDD ?
Hello,
Would you know if there is an installer for K6-2 - 64 MB RAM - 4.3 GB HDD?
(goal is bare console use, and likely prboom on SDL).
A live would be too nice for testing before installation (long, on such low spec hardware).
Thank you very much for your helpful inputs !
#2 2018-11-03 13:04:10
arnaiz
Re: Devuan for K6-2 - 64 MB RAM - 4.3 GB HDD ?
Following Debian stable minimum requirements, it seems that you cant:
https://www.debian.org/releases/stable/ … 04.html.en
But, this requirements maybe are over sized:
The actual minimum memory requirements are a lot less than the numbers listed in this table
Also, Systemd its more memory hungry, so the best you can do its to try and see what happen.
I think it would be possible to install and boot successfully, but likely will works to slow.
#3 2018-11-03 14:33:45
Try the minimal-live disk.  You can read about it here.
