#1 2018-09-11 03:58:30
debliter
error when install steam
hello, when i try to install steam occurs this:
ian@potato:~$ sudo apt install steam
Building dependency tree
  nvidia-egl-common
Use 'sudo apt autoremove' to remove it.
  gcc-6-base:i386 libbsd0:i386 libc6:i386 libdrm-amdgpu1:i386
  libdrm-intel1:i386 libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386
  libedit2:i386 libelf1:i386 libeudev1:i386 libexpat1:i386 libffi6:i386
  libgcc1:i386 libgcrypt20:i386 libgl1-mesa-dri:i386 libgl1-mesa-glx:i386
  libglapi-mesa:i386 libgpg-error0:i386 libllvm3.9:i386 libncurses5:i386
  libpciaccess0:i386 libpcre3:i386 libselinux1:i386 libsensors4:i386
  libstdc++6:i386 libtinfo5:i386 libtxc-dxtn-s2tc:i386 libx11-6:i386
  libx11-xcb1:i386 libxau6:i386 libxcb-dri2-0:i386 libxcb-dri3-0:i386
  libxcb-glx0:i386 libxcb-present0:i386 libxcb-sync1:i386 libxcb1:i386
  libxdamage1:i386 libxdmcp6:i386 libxext6:i386 libxfixes3:i386
  libxinerama1:i386 libxshmfence1:i386 libxxf86vm1:i386 zlib1g:i386
Suggested packages:
  glibc-doc:i386 locales:i386 rng-tools:i386 lm-sensors:i386
  steam-devices:i386
Recommended packages:
  libgpm2:i386 zenity:i386 libxss1:i386
  libxinerama1:i386 libxshmfence1:i386 libxxf86vm1:i386 steam:i386 zlib1g:i386
0 upgraded, 46 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/26.4 MB of archives.
After this operation, 202 MB of additional disk space will be used.
Extracting templates from packages: 100%
Preconfiguring packages ...
(Reading database ... 113359 files and directories currently installed.)
Preparing to unpack .../00-gcc-6-base_6.3.0-18+deb9u1_i386.deb ...
Unpacking gcc-6-base:i386 (6.3.0-18+deb9u1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/00-gcc-6-base_6.3.0-18+deb9u1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/gcc-6-base/TODO.Debian', which is different from other instances of package gcc-6-base:i386
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Preparing to unpack .../01-libgcc1_1%3a6.3.0-18+deb9u1_i386.deb ...
Unpacking libgcc1:i386 (1:6.3.0-18+deb9u1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/01-libgcc1_1%3a6.3.0-18+deb9u1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libgcc1', which is different from other instances of package libgcc1:i386
Preparing to unpack .../02-libc6_2.24-11+deb9u3_i386.deb ...
Unpacking libc6:i386 (2.24-11+deb9u3) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/02-libc6_2.24-11+deb9u3_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libc6/BUGS', which is different from other instances of package libc6:i386
Preparing to unpack .../03-libpcre3_2%3a8.39-3_i386.deb ...
Unpacking libpcre3:i386 (2:8.39-3) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/03-libpcre3_2%3a8.39-3_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libpcre3/AUTHORS', which is different from other instances of package libpcre3:i386
Preparing to unpack .../04-libxau6_1%3a1.0.8-1_i386.deb ...
Unpacking libxau6:i386 (1:1.0.8-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/04-libxau6_1%3a1.0.8-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libxau6/changelog.Debian.gz', which is different from other instances of package libxau6:i386
Preparing to unpack .../05-libstdc++6_6.3.0-18+deb9u1_i386.deb ...
Unpacking libstdc++6:i386 (6.3.0-18+deb9u1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/05-libstdc++6_6.3.0-18+deb9u1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libstdc++6', which is different from other instances of package libstdc++6:i386
Preparing to unpack .../06-libbsd0_0.8.3-1_i386.deb ...
Unpacking libbsd0:i386 (0.8.3-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/06-libbsd0_0.8.3-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libbsd0/changelog.Debian.gz', which is different from other instances of package libbsd0:i386
Preparing to unpack .../07-libxdmcp6_1%3a1.1.2-3_i386.deb ...
Unpacking libxdmcp6:i386 (1:1.1.2-3) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/07-libxdmcp6_1%3a1.1.2-3_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libxdmcp6/changelog.Debian.gz', which is different from other instances of package libxdmcp6:i386
Preparing to unpack .../08-libxcb1_1.12-1_i386.deb ...
Unpacking libxcb1:i386 (1.12-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/08-libxcb1_1.12-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libxcb1/changelog.Debian.gz', which is different from other instances of package libxcb1:i386
^XPreparing to unpack .../09-libx11-6_2%3a1.6.4-3_i386.deb ...
Unpacking libx11-6:i386 (2:1.6.4-3) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/09-libx11-6_2%3a1.6.4-3_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libx11-6/NEWS.Debian.gz', which is different from other instances of package libx11-6:i386
Preparing to unpack .../10-libselinux1_2.6-3+b3_i386.deb ...
Unpacking libselinux1:i386 (2.6-3+b3) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/10-libselinux1_2.6-3+b3_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libselinux1/changelog.Debian.gz', which is different from other instances of package libselinux1:i386
cPreparing to unpack .../11-libeudev1_3.2.2-13_i386.deb ...
Unpacking libeudev1:i386 (3.2.2-13) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/11-libeudev1_3.2.2-13_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libeudev1/changelog.Debian.gz', which is different from other instances of package libeudev1:i386
Preparing to unpack .../12-libxext6_2%3a1.3.3-1+b2_i386.deb ...
Unpacking libxext6:i386 (2:1.3.3-1+b2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/12-libxext6_2%3a1.3.3-1+b2_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libxext6/changelog.Debian.gz', which is different from other instances of package libxext6:i386
Preparing to unpack .../13-libxinerama1_2%3a1.1.3-1+b3_i386.deb ...
Unpacking libxinerama1:i386 (2:1.1.3-1+b3) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/13-libxinerama1_2%3a1.1.3-1+b3_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libxinerama1/changelog.Debian.gz', which is different from other instances of package libxinerama1:i386
Selecting previously unselected package libtxc-dxtn-s2tc:i386.
Preparing to unpack .../14-libtxc-dxtn-s2tc_1.0+git20151227-2_i386.deb ...
Unpacking libtxc-dxtn-s2tc:i386 (1.0+git20151227-2) ...
Preparing to unpack .../15-libdrm2_2.4.74-1_i386.deb ...
Unpacking libdrm2:i386 (2.4.74-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/15-libdrm2_2.4.74-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libdrm2/NEWS.Debian.gz', which is different from other instances of package libdrm2:i386
Preparing to unpack .../16-libdrm-amdgpu1_2.4.74-1_i386.deb ...
Unpacking libdrm-amdgpu1:i386 (2.4.74-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/16-libdrm-amdgpu1_2.4.74-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libdrm-amdgpu1/changelog.Debian.gz', which is different from other instances of package libdrm-amdgpu1:i386
Preparing to unpack .../17-zlib1g_1%3a1.2.8.dfsg-5_i386.deb ...
Unpacking zlib1g:i386 (1:1.2.8.dfsg-5) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/17-zlib1g_1%3a1.2.8.dfsg-5_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/zlib1g/changelog.Debian.gz', which is different from other instances of package zlib1g:i386
Preparing to unpack .../18-libpciaccess0_0.13.4-1+b2_i386.deb ...
Unpacking libpciaccess0:i386 (0.13.4-1+b2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/18-libpciaccess0_0.13.4-1+b2_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libpciaccess0/changelog.Debian.gz', which is different from other instances of package libpciaccess0:i386
Preparing to unpack .../19-libdrm-intel1_2.4.74-1_i386.deb ...
Unpacking libdrm-intel1:i386 (2.4.74-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/19-libdrm-intel1_2.4.74-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libdrm-intel1/changelog.Debian.gz', which is different from other instances of package libdrm-intel1:i386
Preparing to unpack .../20-libdrm-nouveau2_2.4.74-1_i386.deb ...
Unpacking libdrm-nouveau2:i386 (2.4.74-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/20-libdrm-nouveau2_2.4.74-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libdrm-nouveau2/changelog.Debian.gz', which is different from other instances of package libdrm-nouveau2:i386
Preparing to unpack .../21-libdrm-radeon1_2.4.74-1_i386.deb ...
Unpacking libdrm-radeon1:i386 (2.4.74-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/21-libdrm-radeon1_2.4.74-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libdrm-radeon1/changelog.Debian.gz', which is different from other instances of package libdrm-radeon1:i386
Preparing to unpack .../22-libelf1_0.168-1_i386.deb ...
Unpacking libelf1:i386 (0.168-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/22-libelf1_0.168-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libelf1/changelog.Debian.gz', which is different from other instances of package libelf1:i386
Preparing to unpack .../23-libexpat1_2.2.0-2+deb9u1_i386.deb ...
Unpacking libexpat1:i386 (2.2.0-2+deb9u1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/23-libexpat1_2.2.0-2+deb9u1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libexpat1/changelog.Debian.gz', which is different from other instances of package libexpat1:i386
Preparing to unpack .../24-libgpg-error0_1.26-2_i386.deb ...
Unpacking libgpg-error0:i386 (1.26-2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/24-libgpg-error0_1.26-2_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libgpg-error0/README.gz', which is different from other instances of package libgpg-error0:i386
Preparing to unpack .../25-libgcrypt20_1.7.6-2+deb9u3_i386.deb ...
Unpacking libgcrypt20:i386 (1.7.6-2+deb9u3) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/25-libgcrypt20_1.7.6-2+deb9u3_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libgcrypt20/AUTHORS.gz', which is different from other instances of package libgcrypt20:i386
Preparing to unpack .../26-libtinfo5_6.0+20161126-1+deb9u2_i386.deb ...
Unpacking libtinfo5:i386 (6.0+20161126-1+deb9u2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/26-libtinfo5_6.0+20161126-1+deb9u2_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libtinfo5/FAQ', which is different from other instances of package libtinfo5:i386
Preparing to unpack .../27-libncurses5_6.0+20161126-1+deb9u2_i386.deb ...
Unpacking libncurses5:i386 (6.0+20161126-1+deb9u2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/27-libncurses5_6.0+20161126-1+deb9u2_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libncurses5', which is different from other instances of package libncurses5:i386
Preparing to unpack .../28-libedit2_3.1-20160903-3_i386.deb ...
Unpacking libedit2:i386 (3.1-20160903-3) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/28-libedit2_3.1-20160903-3_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libedit2/TODO.Debian', which is different from other instances of package libedit2:i386
Preparing to unpack .../29-libffi6_3.2.1-6_i386.deb ...
Unpacking libffi6:i386 (3.2.1-6) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/29-libffi6_3.2.1-6_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libffi6/changelog.Debian.gz', which is different from other instances of package libffi6:i386
Preparing to unpack .../30-libllvm3.9_1%3a3.9.1-9_i386.deb ...
Unpacking libllvm3.9:i386 (1:3.9.1-9) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/30-libllvm3.9_1%3a3.9.1-9_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libllvm3.9/NEWS.Debian.gz', which is different from other instances of package libllvm3.9:i386
Preparing to unpack .../31-libsensors4_1%3a3.4.0-4_i386.deb ...
Unpacking libsensors4:i386 (1:3.4.0-4) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/31-libsensors4_1%3a3.4.0-4_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libsensors4/NEWS.Debian.gz', which is different from other instances of package libsensors4:i386
Preparing to unpack .../32-libgl1-mesa-dri_13.0.6-1+b2_i386.deb ...
Unpacking libgl1-mesa-dri:i386 (13.0.6-1+b2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/32-libgl1-mesa-dri_13.0.6-1+b2_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libgl1-mesa-dri/changelog.Debian.gz', which is different from other instances of package libgl1-mesa-dri:i386
Preparing to unpack .../33-libglapi-mesa_13.0.6-1+b2_i386.deb ...
Unpacking libglapi-mesa:i386 (13.0.6-1+b2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/33-libglapi-mesa_13.0.6-1+b2_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libglapi-mesa/changelog.Debian.gz', which is different from other instances of package libglapi-mesa:i386
Preparing to unpack .../34-libx11-xcb1_2%3a1.6.4-3_i386.deb ...
Unpacking libx11-xcb1:i386 (2:1.6.4-3) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/34-libx11-xcb1_2%3a1.6.4-3_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libx11-xcb1/changelog.Debian.gz', which is different from other instances of package libx11-xcb1:i386
Preparing to unpack .../35-libxcb-dri2-0_1.12-1_i386.deb ...
Unpacking libxcb-dri2-0:i386 (1.12-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/35-libxcb-dri2-0_1.12-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libxcb-dri2-0/changelog.Debian.gz', which is different from other instances of package libxcb-dri2-0:i386
Preparing to unpack .../36-libxcb-dri3-0_1.12-1_i386.deb ...
Unpacking libxcb-dri3-0:i386 (1.12-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/36-libxcb-dri3-0_1.12-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libxcb-dri3-0/changelog.Debian.gz', which is different from other instances of package libxcb-dri3-0:i386
Preparing to unpack .../37-libxcb-glx0_1.12-1_i386.deb ...
Unpacking libxcb-glx0:i386 (1.12-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/37-libxcb-glx0_1.12-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libxcb-glx0/changelog.Debian.gz', which is different from other instances of package libxcb-glx0:i386
Preparing to unpack .../38-libxcb-present0_1.12-1_i386.deb ...
Unpacking libxcb-present0:i386 (1.12-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/38-libxcb-present0_1.12-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libxcb-present0/changelog.Debian.gz', which is different from other instances of package libxcb-present0:i386
Preparing to unpack .../39-libxcb-sync1_1.12-1_i386.deb ...
Unpacking libxcb-sync1:i386 (1.12-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/39-libxcb-sync1_1.12-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libxcb-sync1/changelog.Debian.gz', which is different from other instances of package libxcb-sync1:i386
Preparing to unpack .../40-libxfixes3_1%3a5.0.3-1_i386.deb ...
Unpacking libxfixes3:i386 (1:5.0.3-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/40-libxfixes3_1%3a5.0.3-1_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libxfixes3/changelog.Debian.gz', which is different from other instances of package libxfixes3:i386
Preparing to unpack .../41-libxdamage1_1%3a1.1.4-2+b3_i386.deb ...
Unpacking libxdamage1:i386 (1:1.1.4-2+b3) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/41-libxdamage1_1%3a1.1.4-2+b3_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libxdamage1/changelog.Debian.gz', which is different from other instances of package libxdamage1:i386
^VPreparing to unpack .../42-libxshmfence1_1.2-1+b2_i386.deb ...
Unpacking libxshmfence1:i386 (1.2-1+b2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/42-libxshmfence1_1.2-1+b2_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libxshmfence1/changelog.Debian.gz', which is different from other instances of package libxshmfence1:i386
Preparing to unpack .../43-libxxf86vm1_1%3a1.1.4-1+b2_i386.deb ...
Unpacking libxxf86vm1:i386 (1:1.1.4-1+b2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/43-libxxf86vm1_1%3a1.1.4-1+b2_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libxxf86vm1/changelog.Debian.gz', which is different from other instances of package libxxf86vm1:i386
Preparing to unpack .../44-libgl1-mesa-glx_13.0.6-1+b2_i386.deb ...
Unpacking libgl1-mesa-glx:i386 (13.0.6-1+b2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-LBfR8F/44-libgl1-mesa-glx_13.0.6-1+b2_i386.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libgl1-mesa-glx/changelog.Debian.gz', which is different from other instances of package libgl1-mesa-glx:i386
Selecting previously unselected package steam:i386.
Preparing to unpack .../45-steam_1.0.0.54-2_i386.deb ...
Unpacking steam:i386 (1.0.0.54-2) ...
I use Crowz Linux but but it happens in the same way with devuan. And have propietary drivers nvidia 385. any help :"v?
