#1 2018-07-22 12:58:30
Terence
KDE-5/Plasma-5 homogeneous Appearance, missing Icons & irregular Fonts
Hello,
To whom is interested: Preamble:
Since KDE-5/Plasma-5 is very difficult to get a homogeneous desktop appearances, for me as lover of 'breeze-dark' is much more difficult. After long recherches I found the solution and don't want to deprive you.
Under KDE-4 was 'qt4config' app (or something similar) , under KDE-5 I think the name was 'qt5ct' but to be installed over a PPA.
Since we cannot use PPAs... we need another solution also practicable for newbie like myself.
1. Tell DE (KDE-5/Plasma-5) to use always is own session. That was reported as bug for 'kdesudo' https://bugs.kde.org/show_bug.cgi?id=353263 but is necessary also for the appearances especially if you want 'Gtk'-apps have exactly same appearances like the 'Qt's, don't ask me why but without this you can stop go further. If not...:
1.a. Create a text-file e.g with Krusader as admin or over konsole
/etc/sudoers.d/workaround_kde5
1.b. Open the new created file, insert following text/code, one emty line @ end, save and close.
Note: by creating file with 'krusader' the editor will opened automatically!
Defaults env_keep += "KDE_SESSION_VERSION KDE_FULL_SESSION"
2. Rename following two files preserving you to change the configuration @ your intent
mv /etc/xdg/Trolltech.conf /etc/xdg/bak.Trolltech.conf
mv /etc/gtk-3.0/settings.ini /etc/gtk-3.0/bak.settings.ini
3. Create SymLinks to the modifiable configurations-files
ln -s ~/.gtkrc-2.0 /etc/gtk-2.0/gtkrc
ln -s ~/.config/Trolltech.conf /etc/xdg/Trolltech.conf
ln -s ~/.config/gtk-3.0/settings.ini /etc/gtk-3.0/settings.ini
4. Logout and login again or restart the system, finish. Enjoy
From now on you will get the same Colors, Icons, Fonts, etc. configured through 'systemsettings5' and Systemsettings as admin/root. Start 'systemsettings' over 'KickOff' or 'Alt+F2' and insert:
systemsettings5
Start 'systemsettings' as admin/root through 'konsole' with:
sudo -i systemsettings5
Note: A restart of system or logout/in is not necessary, sometime you are recommended to restart the actual running apps
Test: Start both 'Qt' and 'Gtk' (Dolphin, Kate, Krusader, Gimp, etc) apps to see the results even with admin-rights like 'Synaptic' over 'KickOff' or:
sudo -i krusader
Note: Some apps like 'Kate' need 'appearances' to be configured in the app same or sometime 'synaptic' don't overtake the Fonts properly. Those issues are very old and as said can be changed in the app same.
Enjoy & best regards.
#2 2018-08-31 18:11:24
astheroth
Re: KDE-5/Plasma-5 homogeneous Appearance, missing Icons & irregular Fonts
I followed the instructions but on the second stage, I got:
root@devuan:/home/astheroth# mv /etc/xdg/Trolltech.conf /etc/xdg/bak.Trolltech.conf
mv: it couldn't be done `stat' over '/etc/xdg/Trolltech.conf': the file or directory doesn't exist.
root@devuan:/home/astheroth# mv /etc/gtk-3.0/settings.ini /etc/gtk-3.0/bak.settings.ini
mv: it couldn't be done `stat' over '/etc/gtk-3.0/settings.ini': the file or directory doesn't exist
Any idea?
<<Lupus est homo homini, non homo, quom qualis sit non novit>>
#3 2018-09-01 23:34:23
ivanovnegro
As a side note: qt5ct will be available in the future, it is already in testing.
#4 2018-09-05 21:06:48
Terence
Any idea?
That's mine the file is not present, so you don't need to rename/move the original (of course is not present).
Just continue with the other steps.
Best regards
