#1 2018-07-20 14:32:59
Nili
[SOLVED] (Devuan Jessie) libuuid-perl: no longer required
Hello! Today I found that during the update process libuuid-perl wants to be removed.
#! nili ~ $ update
Hit http://pkgmaster.devuan.org jessie InRelease
Hit http://pkgmaster.devuan.org jessie-updates InRelease
Hit http://pkgmaster.devuan.org jessie-security InRelease
Hit http://pkgmaster.devuan.org jessie-backports InRelease
Hit http://pkgmaster.devuan.org jessie/main i386 Packages
Hit http://pkgmaster.devuan.org jessie-updates/main i386 Packages
Hit http://pkgmaster.devuan.org jessie-security/main i386 Packages
Hit http://pkgmaster.devuan.org jessie-backports/main i386 Packages
Ign http://pkgmaster.devuan.org jessie/main Translation-en_US
Ign http://pkgmaster.devuan.org jessie-updates/main Translation-en_US
Ign http://pkgmaster.devuan.org jessie-security/main Translation-en_US
Ign http://pkgmaster.devuan.org jessie-backports/main Translation-en_US
#! nili ~ $ upgrade
Building dependency tree
Calculating upgrade... The following package was automatically installed and is no longer required:
  libuuid-perl
Use 'apt-get autoremove' to remove it.
Done
  linux-base
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 19.7 kB of archives.
After this operation, 46.1 kB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
This is my sources list:
deb http://pkgmaster.devuan.org/merged jessie main
deb http://pkgmaster.devuan.org/merged jessie-updates main
deb http://pkgmaster.devuan.org/merged jessie-security main
deb http://pkgmaster.devuan.org/merged jessie-backports main
First time I see such a thing on the stable, A few ago when actively when i used testing, I faced very often similar situations that came out as temporary bug.
Is it a bug that I just have to wait? OR let it go libuuid-perl? To me it seems not look like a simple package that i should let out. From Debian DSA there is no news for this.
Do someone know anything about this case?
Thank you!
System runs...:
Devuan GNU/Linux 1 (jessie)
Linux coeurlinux 3.16.0-4-686-pae #1 SMP Debian 3.16.51-3 (2017-12-13) i686 GNU/Linux
P.S. update/upgrade command shortened it as alias on .bashrc.
alias update="sudo apt-get update"
alias upgrade="sudo apt-get upgrade"
Edit: Found this SECURITY THREAD about this case.
I gave the update linux-base, removed libuuid-perl and installed again. Currently it seems quiet, i'll look at it later.
This thread is solved! Thank you for the attention.
Nili
Dev1 | StartX | Openbox | Tint2 | Conky-Std
プロトタイプ: 双葉杏 (Futaba Anzu) THE iDOLM@STER、 山田 たえ (Yamada Tae) Zombieland Saga
Nothing beats peace and quiet - Tomoki Sakurai
