#1 2018-06-22 01:57:20
SolidTrump
Steam not working on Devuan [SOLVED]
Hey I am extremely new to Devuan. I switched from Ubuntu 18.04 LTS to Devuan (ascii) and I tried to install Steam. When it was installed I was met with problems and Steam pretty much not running. Could someone help me?
solidtrump@devuan:~$ sudo apt-get update
Hit:1 http://repo.steampowered.com/steam precise InRelease
Hit:2 http://pkgmaster.devuan.org/merged ascii InRelease
Hit:3 http://pkgmaster.devuan.org/merged ascii-updates InRelease
Hit:4 http://pkgmaster.devuan.org/merged ascii-security InRelease
solidtrump@devuan:~$ sudo apt-get install steam
Building dependency tree
  steam-launcher zenity zenity-common
Recommended packages:
  jockey-common
  steam:i386 steam-launcher zenity zenity-common
0 upgraded, 4 newly installed, 0 to remove and 8 not upgraded.
Need to get 998 kB/3,755 kB of archives.
After this operation, 7,044 kB of additional disk space will be used.
Get:1 http://pkgmaster.devuan.org/merged ascii/main amd64 zenity-common all 3.22.0-1 [731 kB]
Get:2 http://pkgmaster.devuan.org/merged ascii/main amd64 zenity amd64 3.22.0-1+b1 [267 kB]
Fetched 998 kB in 0s (2,309 kB/s)
Selecting previously unselected package zenity-common.
(Reading database ... 100286 files and directories currently installed.)
Preparing to unpack .../zenity-common_3.22.0-1_all.deb ...
Unpacking zenity-common (3.22.0-1) ...
Selecting previously unselected package zenity.
Preparing to unpack .../zenity_3.22.0-1+b1_amd64.deb ...
Unpacking zenity (3.22.0-1+b1) ...
Selecting previously unselected package steam-launcher.
Preparing to unpack .../steam-launcher_1.0.0.54_all.deb ...
Unpacking steam-launcher (1.0.0.54) ...
Selecting previously unselected package steam:i386.
Preparing to unpack .../steam_1.0.0.54_i386.deb ...
Unpacking steam:i386 (1.0.0.54) ...
Processing triggers for mime-support (3.60) ...
Processing triggers for desktop-file-utils (0.23-1) ...
Setting up zenity-common (3.22.0-1) ...
Processing triggers for man-db (2.7.6.1-2) ...
Processing triggers for hicolor-icon-theme (0.15-1) ...
Setting up zenity (3.22.0-1+b1) ...
Setting up steam-launcher (1.0.0.54) ...
Setting up steam:i386 (1.0.0.54) ...
solidtrump@devuan:~$ steam
Repairing installation, linking /home/solidtrump/.steam/steam to /home/solidtrump/.local/share/Steam
/home/solidtrump/.local/share/Steam/steam.sh: line 154: VERSION_ID: unbound variable
Running Steam on devuan  64-bit
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(0)
/home/solidtrump/.local/share/Steam/ubuntu12_32/steam: symbol lookup error: /usr/lib/i386-linux-gnu/libxcb-dri3.so.0: undefined symbol: xcb_send_request_with_fds
/home/solidtrump/.local/share/Steam/steam.sh: line 444: no match: ssfn*
I also found this post talking about how to install it simply but it didn't help much at all: https://dev1galaxy.org/viewtopic.php?id=2132
The guy "devuser" helping the author "0xf4b10" said
"I think it's just a matter of setting up multiarch because steam seems to be 32bit only:
dpkg --add-architecture i386
apt-get update
You obviously need to have non-free sources enabled as steam isn't exactly open source. In case you are wondering where your steam client ends up: It's at /usr/games/steam. Run this from GUI and it'll install it's files to your home directory. You need to you have OpenGL support available for it to work though (which i guess you have if you plan to use steam)."
How do you enable "non-free sources"? Is there some setting somewhere to enable it?
My current specs if it helps:
   ..,,;;;::;,..                   solidtrump@devuan
           `':ddd;:,.              -----------------
                 `'dPPd:,.         OS: Devuan GNU/Linux 2.0 (ascii) x86_64
                     `:b$$b`.      Model: Aspire one 1-132 V1.03
                        'P$$$d`    Kernel: 4.9.0-6-amd64
                         .$$$$$`   Uptime: 2 hours, 20 minutes
                         ;$$$$$P   Packages: 1547
                      .:P$$$$$$`   Shell: bash 4.4.12
                  .,:b$$$$$$$;'    Resolution: 1366x768
             .,:dP$$$$$$$$b:'      DE: XFCE
      .,:;db$$$$$$$$$$Pd'`         WM: Xfwm4
 ,db$$$$$$$$$$$$$$b:'`             Theme: Clearlooks-Phenix-DarkPurpy [GTK2], A
:$$$$$$$$$$$$b:'`                  Icons: DarkPurpy [GTK2], Adwaita [GTK3]
 `$$$$$bd:''`                      Terminal: xfce4-terminal
   `'''`                           CPU: Intel Celeron N3060 (2) @ 2.4GHz
                                   GPU: Intel Integrated Graphics
                                   Memory: 1462MB / 1917MB
Side note: I know my specs are garbage pls no bully
#2 2018-06-22 04:45:31
Dutch_Master
Re: Steam not working on Devuan [SOLVED]
You need to add both contrib and non-free to /etc/apt/sources.list to enable these. Make sure you do
apt-get update
before attempting to install stuff from these repo's.
#3 2018-06-22 06:59:43
devuser
What Dutch_Master said. Also i'd make sure to remove the steampowered repo and whatever was installed from it before attempting to install steam from the Devuan repos. If the problem persists i guess steam has once again broken the compatibility with Debian and thereby Devuan. Might be possible wot work around this but lets see if it works from the official packages first.
#4 2018-06-22 20:39:18
SolidTrump
apt-get update
Yes but how do I do that exactly?
#5 2018-06-22 20:43:40
SolidTrump
Do I just drop contrib and non-free in the file?
#6 2018-06-22 21:07:22
Add those to the line in `/etc/apt/sources.list`
#7 2018-06-22 21:13:34
SolidTrump
Excuse me for my ignorance but where in the line?
## package repositories
deb http://pkgmaster.devuan.org/merged ascii main
deb http://pkgmaster.devuan.org/merged ascii-updates main
deb http://pkgmaster.devuan.org/merged ascii-security main
#deb http://pkgmaster.devuan.org/merged ascii-backports main
## source repositories
#deb-src http://pkgmaster.devuan.org/merged ascii main
#deb-src http://pkgmaster.devuan.org/merged ascii-updates main
#deb-src http://pkgmaster.devuan.org/merged ascii-security main
#deb-src http://pkgmaster.devuan.org/merged ascii-backports main
#8 2018-06-22 21:26:26
SolidTrump
Like I said I am very new so I am really unfamiliar with Devuan.
#9 2018-06-22 21:31:34
I'm not sure which lines will need the addition so I only did one as an example
deb http://pkgmaster.devuan.org/merged ascii main contrib non-free
#deb-src http://pkgmaster.devuan.org/merged ascii main  contrib
#10 2018-06-22 22:18:04
SolidTrump
It works! Thanks everyone who helped!
This is what my source list looks like now:
deb http://pkgmaster.devuan.org/merged ascii-updates main contrib non-free
deb http://pkgmaster.devuan.org/merged ascii-security main contrib non-free
#deb http://pkgmaster.devuan.org/merged ascii-backports main contrib non-free
#deb-src http://pkgmaster.devuan.org/merged ascii main contrib non-free
#deb-src http://pkgmaster.devuan.org/merged ascii-updates main contrib non-free
#deb-src http://pkgmaster.devuan.org/merged ascii-security main contrib non-free
#deb-src http://pkgmaster.devuan.org/merged ascii-backports main contrib non-free
I was wondering what I should make non-free and just went "fuck it". I think this thread should be pinned somewhere so in the future people won't have to go through such a hassle like I did.
#11 2018-06-23 01:51:37
Please mark this thread as [Solved] in the subject.  Thanks
#12 2018-06-25 01:20:06
SolidTrump
how exactly?
#13 2018-06-25 01:42:45
SolidTrump wrote:
how exactly?
Click edit at the bottom of your first post and add [Solved] before the subject.
