#1 2018-05-01 11:46:42
wdq
How to install TV-MAXE live tv on DEVUAN
TV-MAXE live tv most of the channels Romanian a few international but you can add your own list of channels, uses sopcast
let us start first you need " gdebi " so we can install everything with dependencies, if you do not have gdebi you can install it by running
 apt-get install gdebi
if you do not preffer all the recommended software you can add to the command no install recommends
 apt-get install gdebi --no-install-recommends
ONLY FOR DEVUAN ASCII USERS / FLUXUAN / MIYO ASCII and all other DEVUAN ASCII Derivatives
##### !!!! FOR THE USERS THAT USES DEVUAN ASCII YOU NEED TO ADD DEVUAN JESSIE MAIN IN SOURCES.LIST !!!! #####
echo "deb http://auto.mirror.devuan.org/merged jessie main" | tee -a /etc/apt/sources.list
apt-get update
to remove it after install
nano /etc/apt/sources.list
and remove the JESSIE main line
#### Why do you need the repos from jessie ? , Because gstreamer0.10 is not available in ASCII anymore but is available in jessie ####
PLEASE DOWNLOAD AND INSTALL IN THE ORDER THAT YOU SEE DOWN ---- 1 2 3 4 ------
next we need a few dependencies witch are sp-auth, python-imaging-compat, python-virtkey that can be downloaded from
1 -SP-AUTH 32 bit
1 -SP-AUTH 64 bit
2 -Python-Imaging-Compat 32 bit
2 -Python-Imaging-Compat 64 bit
3 -Python-VirtKey 32 bit
3 -Python-VirtKey 64 bit
4 -TV-MAXE 32 bit
4 -TV-MAXE 64 bit
AFTER RUN GO TO TOP LEFT CORNER CLICK ON TV-MAXE THEN CLICK ON PREFERENCES AND AT THE USE INTERNAL PLAYER
PLAYER BACKEND: SELECT --- >  VLC-tvmx CLICK SAVE CHOOSE A CHANNEL AND ENJOY !
RESULT
#2 2018-05-01 12:10:20
wdq
Re: How to install TV-MAXE live tv on DEVUAN
For Any PRoblems Related Please Post Here !
