#1 2018-02-01 09:36:16
devur
[SOLEVD] devuan-keyring
i got a error when i update and upgade. i haw renewed my repository list and now i will renew the keyring file, but where to do i save the devua-keyring file
keyring  repository@devuan.org
error
from synaptic
W: Duplicate sources.list entry http://auto.mirror.devuan.org/merged/ jessie-updates/main amd64 Packages (/var/lib/apt/lists/auto.mirror.devuan.org_merged_dists_jessie-updates_main_binary-amd64_Packages)
Laptop lenovo
Desktop XFCE
Os Devuan GNU/Linux
#2 2018-02-01 16:04:46
nixer
Re: [SOLEVD] devuan-keyring
Try this, as root,
apt-get install devuan-keyring
If you still get the following error,
then look in /etc/apt/sources.list file and make sure that there is only one line containing
If you see only one mention of that line, then look in /etc/apt/sources.list.d/ for that line also.
I think that that line should be:
and should only appear once, preferably in the sources.list file.
#3 2018-02-10 09:41:13
devur
slowed.  the problem developed and i haw made a new installation
Laptop lenovo
Desktop XFCE
Os Devuan GNU/Linux
#4 2018-03-04 07:53:26
rfgmm
hey guys it is related with this issue, my problem about being unable to mount removable drivers?
