#1 2018-01-08 17:46:42
fungus
ATK bridge not found [SOLVED]
I have seen this warning/error message about ATK-bridge not found recently, unfortunately I can't remember the instance and can't reproduce at the moment.
I looked through pkgs and the only thing relevant is this.
libatk-bridge2.0-0/testing,now 2.22.0-2 amd64 [installed,automatic]
  AT-SPI 2 toolkit bridge - shared library
What exactly does this thing do and why wouldn't it be found?
#2 2018-01-11 16:54:34
Geoff 42
Re: ATK bridge not found [SOLVED]
I get an error message too. When I run gksu 'rxvt -rv' I get the message :-
Gtk-Message: Failed to load module "atk-bridge"
Gkr-Message: secret service operation failed: The name org.freedesktop.secrets was not provided by any .service files
The command does run and the processes which run are :-
xxxxxx    2862  0.3  0.2 172624 20548 pts/0    S    16:44   0:00                  |   |       \_ gksu rxvt -rv
root      2869  0.0  0.0  46864  2672 pts/1    Ss+  16:44   0:00                  |   |           \_ /bin/su root -c /usr/lib/libgksu/gksu-run-helper "rxvt -rv"
root      2871  0.0  0.0  12004  1088 ?        Ss   16:44   0:00                  |   |               \_ /usr/lib/libgksu/gksu-run-helper rxvt -rv
root      2875  0.0  0.0   4292   756 ?        S    16:44   0:00                  |   |                   \_ sh -c rxvt -rv
root      2876  0.0  0.1 107008 13616 ?        S    16:44   0:00                  |   |                       \_ rxvt -rv
root      2877  0.0  0.0  94932  4408 ?        S    16:44   0:00                  |   |                           \_ rxvt -rv
root      2879  0.0  0.0  19992  3752 pts/2    Ss+  16:44   0:00                  |   |                           \_ bash
Is it something to do with gksu-run-helper?
Geoff
#3 2018-01-11 17:18:51
Geoff 42
I see that libgksu2-0 depends on libatk1.0-0
Geoff
#4 2018-01-11 20:59:39
cynwulf
Maybe missing dbus "plumbing"...  probably an error you can safely ignore?  (as with most of the crap gtk spits out)
https://packages.debian.org/source/jessie/at-spi2-atk
You could try installing "libatk-adaptor" (the only other relevant binary built from that source package) and see if that "silences" it...
#5 2018-01-12 14:22:42
Geoff 42
libatk-adaptor had not been installed, so I have now installed it. When I ran gksu there was no error message, although there was not always an error message, so it will take some time to verify that it has really fixed it.
Thank you for the suggestion.
Geoff
#6 2018-01-12 17:18:18
fungus
$ pcmanfm
apt install libatk-adaptor
$ pcmanfm
Right-on!
