#1 2017-08-29 07:26:42
soohwa
Make a mirror of devuan package repository with a modified debmirror
If you want to create a devuan mirror with debmirror (for example for jessie) you must modify the debmirror perl script as here :
https://github.com/soohwa/devuan-debmirror
You can find the difference with the original :
https://github.com/soohwa/devuan-debmir … its/master
And mirror with :
https://github.com/soohwa/devuan-debmir … /README.md
debmirror /mirror/devuan/ \
	--host=packages.devuan.org \
	--arch=i386,amd64 \
	--dist=jessie,jessie-backports,jessie-proposed-updates,jessie-security,jessie-updates \
	--omit-suite-symlinks \
	--diff=none \
	--root=merged \
	--verbose \
	--i18n \
	--method=http \
	--keyring /mirror/541922FB.bin
541922FB.bin is the public key for devuan repositories.
#2 2017-08-29 07:43:54
Re: Make a mirror of devuan package repository with a modified debmirror
You are jumping the gun here.  Package mirrors will need to be set up in a specific way.  Please wait for the official instructions.
In the meantime this might be instructive:
https://lists.dyne.org/lurker/message/2 … fe.en.html
#3 2017-08-29 11:44:42
soohwa
Sorry, i did not want to be offensive. I never wanted to make a public mirror. That method just works fine for me for a local private mirror. This works while waiting for the official instructions with rsync and I just wanted others to enjoy it.
#4 2017-08-29 15:56:13
Ah, thanks for clarifying.  My concern was indeed that you were using that to set up a public mirror and that seemed like a rather odd first post.  Enjoy your time here.  Hope we're all good now that that's been straightened out.  smile
#5 2017-08-30 18:39:01
mckaygerhard
just what i look it for!
hell yeah! many many thanks... i'll make a complete how to for that!
this work for those that not have internet connection
go to a cybercafe
attach the usb disk
download with debmirror
detach the usb disk
go to your home or work
use locally with "file://" or bypassing with webserver with "htttp://localhost"
or if you have a router, set a ip and use as normal repository.. just added to boot screen allow_unantenticated=true (or something)
#6 2018-02-23 07:55:53
mckaygerhard
hi after several try's i cannot mirror ONLY the devuan pacakges, just mirrored ALLL and i dont need the debian package
i just want to mirror ONLY THE DEVUAN MODIFIED RESPECT THE DEBIAN PACKJAGES please some one has tokown how to do so?
as can see it, start always to download the debian packages startirng by the 90ad data package that are huge large size
[100%] Getting: dists/jessie/non-free/binary-i386/Release... ok
Parse Packages and Sources files and add to the file list everything therein.
Download all files that we need to get (42511 MiB).
Get package files.
[  0%] Getting: pool/DEBIAN/main/0/0ad-data/0ad-data-common_0.0.17-1_all.deb... ok
[  0%] Getting: pool/DEBIAN/main/0/0ad-data/0ad-data_0.0.17-1_all.deb
#7 2018-02-23 15:37:03
Devuan filters the Debian packages.  If you use Debian packages directly, chances are that eventually something will slip in and break your system or you won't be able to upgrade properly.
#8 2018-02-23 23:15:44
mckaygerhard
give me a break! I'M USING DEVUAN ANBD I'M TRY TO MIRRROR ONLY DEVUAN NOT MERGED PACKAGES WITH DEVUAN DEBMIRROR PACKAGE
without modification does not mirrored well the devuan repositories
#9 2018-02-23 23:35:30
I guess you didn't see the response to your bug report.  I assume that was written by KatolaZ:
Your bug report is not that useful, since you must include the
relevant content of the debmirror.conf file that you are using.
In order to mirror only devuan-specific suites in ascii for amd64,
your debmirror.conf should have something like:
$host="pkgmaster.devuan.org";
$remoteroot="devuan";
$download_method="http";
@dists="ascii";
@sections="main,main/debian-installer,contrib,non-free";
@arches="amd64";
I have tried it now myself with:
$ debmirror -p --keyring=/usr/share/keyrings/devuan-archive-keyring.gpg ./devuan-only
and it works.
So sounds like PEBKAC.
#10 2018-02-24 00:18:44
mckaygerhard
WOW I finally get what I need! umm that mail still not arrive it to gmail!
well many many thank, for the first time o got a right anwers and got support from devuan... so lest make some mirror now! THANKS
#11 2018-02-24 00:24:21
Happy mirroring!!
#12 2018-02-24 01:59:40
mckaygerhard
the complete command line, i do not use that stupid config file
debmirror-devuan  \
 --ignore-missing-release  --ignore-release-gpg \
 --nocleanup --diff=none \
 --source --section=main,main/debian-installer,contrib,non-free  --arch=i386 --dist=jessie  --omit-suite-symlinks \
 --host=pkgmaster.devuan.org --root=devuan --method=http \
 --progress --verbose \
 mirrordirectorydebs
in this case i386, all section including non-free, only jessie, no diff or cleanup if someting goes wrong or faill, rest of options are same as debian
no w i have locally the two flavors, and i see how systemd are invadoing more and more lijnux system arrggggggg
#13 2018-06-05 10:47:55
haary
And mirror with :
With all three URLs I am getting a 404 error now - maybe  migrated  elsewhere after the MS takeover?
#14 2018-06-05 11:59:10
mckaygerhard
ah the MS takeover!! yes now many github project will migrate to gitlab! yes!
well i not found any similar at gitlab
but i think that this are not necesary.. do you read the complete threath?
