#1 2017-07-14 17:48:26
Kingneutron
d1g
Testing/ascii will not install due to rsyslog dependencies
Installing in Virtualbox (host is Linux Ubuntu 14.04), non-graphical Expert install with squid proxy enabled for downloads
Install media: Using devuan_jessie_1.0.0-beta_amd64_DVD.iso from torrent, dated Aug 27 2016
From tty4 Error: rsyslog depends on libjson-c2 >= 0.10 however package libjson-c2 is not installed
Also depends on liblognorm2
Screenshots attached (error message and VM details)[devuan-testing-install-errors.zip](/uploads/733725c8f8c3c8d2d88c6a7bbd6926f1/devuan-testing-install-errors.zip)
________________________________________
Project: devuan/devuan-project
Issue: #88
By: Kingneutron
#2 2017-09-05 21:48:59
Re: Testing/ascii will not install due to rsyslog dependencies
Try a syslog-ng or the busybox syslog variant...
#3 2017-09-05 21:54:55
@zapper . . . That would need to be posted on https://git.devuan.org/devuan/devuan-project/issues/88 for Kingneutron or anyone else to see it.  I'll try to do that later unless you get to it first
